Question about Dryers
Sears model 417.91702000 dryer problems - Dryers
Replace kenmore dryer drive belt
Go to www.repairclinic.com and enter 110.76902693. Be sure to enter the model exactly as I have shown. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of major parts.
Dec 07, 2016 | Kenmore Dryers
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Kenmore elite dryer front panel not on
I just went through this with my dryer. I started by replacing the controller board which was the less expensive part and after finding that not to be the problem I then replaced the Touchpad. Problem solved! I found a rebuilt controller board on amazon for half price which I left on the dryer even after finding it was not the problem then ordered the touchpad from a friend that has a parts store. I could only save $30 by purchasing this way but a penny saved is a penny earned. Anyway my dryer was doing exactly what yours is doing and had I to do it over, I would start with the touch pad from Sears.com for $288 and change. Plus shipping of course unless you have a sears parts store near you. Go to download manuals at sears.com and enter you dryer model number. Mine was 110.8586.1400. I hope this helps.
Jun 28, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer not turning on.........before I would change the timer setting and it would would work.......after a couple of weeks, when i change the timer setting it wouldn't turn on at all. Question is
Definitely sounds like a timer problem. Sears Parts Direct should have your part. The model # you supplied is incomplete to determine if you have a gas or electric dryer. Check the model # again and go to Sears page to find the correct part.
May 08, 2012 | General Electric DBXR463EG Dryer
I have a sears Kenmore Dryer Model # 41784042500. In the Manual it describes my problem (drum turns but no heat) the manual says I need to replace one of two fuses. But when I call sears they have no part...
Hi ray7112....
Sometimes fuses are called by different names, check and see if they call it by any of these names.
1...Fuse
2...Thermistor
3...thermostat
4. Thermal cutout
Please take time to rate me
Aug 23, 2011 | Dryers
Is this the right number for my dryer?
Yes the Model Number on most all sears Kenmore products have a 3 didget code a dot then the rest of the model number. The first 3 numbers denote the manufacturer.
Mar 13, 2009 | Kenmore Dryers
No heat
Sears Kenmore electric dryer model #110.96320100 will not get hot.
Nov 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
