Question about Garmin nuvi 250W GPS Receiver
Map upgrade How do I know if the maps were downloaded on my gamin gps.
  • Garmin Master
  • 2,130 Answers
Check the map menu to see if the new map is on the unit. At the main menu, press the tools button then the map icon. Then press the "map info" button. Look to see if the listing shows the new map that you just downloaded or if the original older map is still there. Make sure that the map is enabled by a check mark next to the map listing.
Posted on Apr 26, 2013
  • 174 Answers
SOURCE: garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Posted on Jan 15, 2008
  • 638 Answers
SOURCE: How to Transfer Maps to GPSmap 60csx
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Posted on Apr 01, 2008
SOURCE: Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
Posted on Jul 09, 2008
marcelbakker
  • 174 Answers
SOURCE: deleted maps on my garmin gps nuvi 255w now what???
Wasn't there a dvd with the product?
Posted on Jul 23, 2008
  • 20 Answers
SOURCE: Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Posted on Jan 20, 2009
L do I know if I have life time updates on my gamin nuvi 100
Usually if you have lifetime traffic and map updates, the model comes with LMT which means Lifetime Map and Traffic updates. Or LM means Lifetime Map updates.
Sep 20, 2014 | Garmin nuvi 1300 Car GPS Receiver
How do down lqad updated maps to my sae nav
Welcome to FixYa.
To upgrade and/or update your Garmin GPS, do the following:
  • To update your Garmin device, go to this link https://my.garmin.com/maps/chooseDeviceType.htm?
  • Select your device type.
  • It will request to install the Gamin Communicator Plug-in.
  • Make sure that you connect your Garmin device to the computer before proceeding to install.
  • After the installation, it will automatically download for an updated map.
Note: Sometimes, there are no available updated maps.
To confirm if there are available maps, contact Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Thank you for using FixYa.
Have a great day.
Jul 18, 2011 | Garmin nuvi 255W GPS Receiver
How do I update my garmin nuvi 660 maps and will it cost me
Welcome to FixYa.
Note: Sometimes, there are no available updated maps. On the process of updating, you will be able to know if you are entitled to a free update or you have to pay.
US: 913-397-8200
Have a great day.
Jul 18, 2011 | Garmin Nuvi 660 GPS Receiver
I don't know how to update my gps.
Welcome to FixYa.
US: 913-397-8200
Have a great day.
Jul 16, 2011 | Garmin nuvi 260W GPS Receiver
How do I register my Grin on line.
Welcome to FixYa.
US: 913-397-8200
Have a great day.
Jul 16, 2011 | Garmin GPS
Want free upgrade
Welcome to FixYa.
To upgrade and/or update your Garmin GPS, do the folloeing:
Welcome to FixYa!
  • To update your Garmin device, go to this linkhttps://my.garmin.com/maps/chooseDeviceType.htm?
US: 913-397-8200
Have a great day.
Jul 12, 2011 | Garmin nuvi 250W GPS Receiver
Need update
go to www.garmin.com and follow the link for the update service
May 30, 2011 | Garmin Nuvi 660 GPS Receiver
We have a garmin nuvi 255w. We need to know what is the latest map update. Our gps has "CN North America, NT 2010.30" version on it. Is ther something newer than this.
Maps for most GPS devices are updated several times a year. Your map is from 2010 and should be updated. You can go to the garmin site and pay to download and install upgraded maps or do a google search for map upgrades and you'll find some services offering lifetime upgrades for a few dollars more than the Garmin one time upgrade. I did this and have had no problems updating the maps on my Garmin Nuvi 250.
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
L am looking for map updates for nextar gps
Unfortunately Nextar GPS systems come with only USA/Canada or UKmaps , maps for other regions are not available, and there are also not much upgrade.
Maps from third party usually do not work on this unit.
The only way to know if a download is available is simply calling them at their toll free numbers, they do not make available online downloads:
Technical Support
1-888-849-0846
Technical Support (For U.K. Only)
0800-047-0126
The good thing is that upgrades and map are both free, while on other models you have to pay for maps.
Give them a call to unlock a download to latest map.
Regards.
May 06, 2009 | Nextar X3-03 Car GPS Receiver
Garmin c330 no map data available
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
