Question about Garden
Zama RB 142
Engine will start and run for a bit in full choke. When you take the choke off it goes high rpm and dies. Replaced all fuel lines, pick up and disassembled the carb and cleaned it. Same problem. What now?
Maybe the hose or the Bulb has a pin hole in it. It will suck air.
Posted on Apr 25, 2013
  • 246 Answers
SOURCE: Engine will only run on 1/2 Choke
Hello edv40026:
Have you Checked the Exhaust Port and Muffler for Restriction?
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect or the Compression is Low (Worn Rings/Cylinder).
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: After rebuild only runs on half choke.Adjusting screw doesn't help
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
Posted on May 26, 2009
  • 112 Answers
SOURCE: Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Posted on Jul 24, 2009
  • 71 Answers
SOURCE: stihl line trimmer starts but won't stay running
check to make sure your kill switch is not shorting and you have the right gap from the coil to the flywheel also if the flywheel sheer pin is damaged in the least this will cause a multitude of problems... it is the timing pin and must be in good shape not damaged or sheered ..any way reply to mrdmburns@cableone.net and i will try to help you through this.... DALE good luck and will wait for reply..
Posted on Aug 29, 2009
  • 36 Answers
SOURCE: Craftsman 25cc weedwacker (358.791030). Zama
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Posted on Sep 22, 2010
1993 HONDA SHADOW VLX 600, STARTS RUNS FOR 5 MINUTES AND DIES, I CHECKED EVERYTHING FUEL RELATED,IT'S NOT A FUEL PROBLEM
From your description you can be fairly certain it is an electronic problem.
I had a similar problem once with my Honda CX500. I found the connections to the ignition module had gone green and a good clean up restored normal running.
Mar 18, 2017 | Honda Motorcycles
Starts with choke but will not run when choke is opened to run position. New Plug, New fuel filter, New gas and oil mixture, new primer bulb, Spark arestor in exhaust port is cleaned. Will stay running...
I've noticed the Echos are cold-blooded and a decent warm-up time is required. You indicate the fuel mixture has to be somewhat rich to keep the engine running. This indicates the needle jets need tweaking to acquire the proper mix (if applicable) or else the fuel pump diaghram is not functioning properly and needs replacement according to the symptoms.
Here is a link to the site that has the G&D (gasket and diaghram) kit and RB (rebuild) kit part numbers for you. You will need to know your machine's model. Link to determine your carb: http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
This is the link to determine the part numbers of the kits. Zama has a great site and informative links:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
Sep 11, 2010 | Echo Garden
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine starts easy. Engine can only achieve high
eitrher a clogged fuel filter thats in the tank, old gasoline or the fuel pump daiphragm in the carb has hardened
Oct 30, 2009 | Echo Inc. 25.4 CC Backpack Blower
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jul 22, 2009 | Ryobi Garden
Gas trimmer hesitates when I try full throttle
Hope my suggestions solved your problem.
Jim
May 18, 2009 | Garden
Blower does not stay running
Make sure you have the propper mix of gasoline and oil. If the fuel is old mix new fuel to proper ratio. Find your manual and find the low speed fuel adjustment and the high speed fuel adjustment on the engine. First, turn the screws in and count the turns so you know where you started. Return the screws to the origional position. Usually 2 to 2-1/2 turns are a good starting point if you get them messed up. If the engine runs with the choke on you have to open the high speed jet a bit, 1/4 turn CCW. Keep trying this and get the feel of the change in the engine performance. If you have too much fuel the engine will not get to peak RPM. The low speed jet works similar but you have to adjust it so the engine idles at a decent RPM. This should get you on the path.
Mar 15, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
