Question about Sony KV-36XBR450 36" TV
Sony KV36XBR450 - no sound
The sound just went off while I was watching. It's not in SAP mode or anything wierd. The surround system works with a DVD just fine, but when you just watch the TV no sound comes thru TV or surround. What could the issue be and would this be a pricey fix?
Thanks for your help
  • jdavis165 Mar 13, 2009
    Thanks - I unplugged cable and restarted.. I HAVE SOUND. Obviously cable is having some issue. Thanks for helping me.. U Rock!
    Brigadier General:
  • 8,619 Answers
Hi!
Check for the cables to the cable box/reciever. What type of cable are you using for connection with the cable box(HDMI,RCA component cables)? Your tv is fine as it is working with the dvd player. The issue is with the cables connecting the cable box or from the cable company. Call them to get more information about this issue(maybe weak signals)
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Posted on Mar 13, 2009
Need to know is there is a input on the back of the sony davdx255 for the tv to recieve surround sound.
Does a TV NEED surround sound if you have a surround sound HIFI? Normal setero sound would probably suffice as the TV might not actually have electroics or speakers to do anything but mic\x it down to lo-fi stereo.
Correlary: You COULD just drag regular RCA audio out of your cable box to the TV if you want to watch the news or talk shows.
Jan 30, 2011 | Sony DAV-DX255 System
LHB953 Theater System: switches to "auto" video mode while watching netfl...
we had the same problem and we hooked the fiber optic cable into the back of the satellite or cable box and then into the back of the surround sound system. we had it first from the tv to the surround sound and only our front ones worked when it was like that
May 17, 2010 | LG LHB953 Theater System
My Sony HDTV has no volume on a few of the channels. All the rest are fine. What's wrong?
Make sure SAP sound mode is turned off. Set to stereo or surround in sound menu. Hope this helps.
Apr 18, 2010 | Televison & Video
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
No sound on my Sony Triniton - video has SAP on it
YOU ARE IN SAP MODE. IF THERE IS NO SECOND AUDIO PROGRAM ON THE STATION YOU ARE WATCHING YOU WILL GET NO AUDIO. SWITCH SAP TO STEREO OR MONO. SOME REMOTES HAVE A MTS BUTTON ON THEM.
Jan 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Sony KV-36XBR450 36" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
