Toshiba CE32E15 picture is too wide
Picture is too wide for the screen
    Genius:
  • Televison & ... Master
  • 2,432 Answers
How about the settings did you tried with other settings like the 4:3 in the aspect ratio. if can not resolved with other settings then it could be a malfunctioned in the horizontal section. check for a bulged or leak capacitor in the horizontal section in the main board.
Posted on Apr 25, 2013
How to make picture wide-screen
Refer its user manual to get details about how to change the aspect ratio to make the picture wide.
Jul 31, 2014 | Toshiba 32L1400 32" LED TV 1366x768, 60...
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba Satellite P105-S6124 Screen lines
Are these lines on the screen during the whole boot process? If so then the screen cpu and/or the video cpu has gone bad. Connect an external monitor. If the picture is clear, no lines, then the problem is the LCD screen. If the lines appear on the external monitor during the boot process then the mother board will need replacement.
Good Luck
Mar 22, 2009 | Toshiba Satellite P105-S6124 Notebook
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
Tv repair
I have discovered that applying light pressure on the video card with a plastic shim corrects a card solder problem with these TVs. (Removing the back is required) In these cases you should be able to see a picture by shining a bright light right next to the screen front. This goes for many screen shutoff problems on flat panel monitors and laptops. Do not put the light there for very long or you will end up with a permanent bright spot burt onto the screen.
Feb 25, 2008 | Toshiba 26HF84 26" TV
Broken screen
all you can do is chase a used
Toshiba (Theater Wide HD) Model NO.20HLV86
or buy a replacement TV
was it covered under contents damage insurance ?
this TV has been discontinued
the design of this screen means its put together
layer by layer .sandwiched ..not just a glass cover
a screen replace can't be done
unless the Toshiba company "TV parts division " has the exact same screen to supply to your local TV repair man
Even finding circuitry boards to be supplied for that model have a slim chance
Apr 11, 2017 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
