Question about Rado Watches
Type of battery for rado watch 150.0472.3.010
NEED BATTERY FOR RADO WATCH 150.0472.3.010
SOURCE: rado watch
Not likely, Best to send it to us for evaluation. It's free! www.Finewatchmaking.com Donald McPherson C.W.
Posted on Sep 19, 2007
SOURCE: watch hands need fixing, re-oil,
I had the same problem , you need to go to a watch store and buy a watch pin to fix the band ,they should install the pin for you .
Posted on Jun 20, 2008
SOURCE: Rado Watch
I brought mine online from http://www.ernestjones.co.uk/webstore/browse/N/65+4294967253
You are better off getting your watch from a credible supplier like Ernest Jones as they come with a guarantee..
Posted on Jan 06, 2009
  • 11 Answers
SOURCE: Rado watch stopped working
It sound like a fault. Be careful who looks at it though and what they charge - a complete new quartz movement for most watches, even fancy ones like your don't cost as much as £90 so almost all of what you are charged is labour.
Posted on Feb 16, 2009
  • 93 Answers
SOURCE: What type of battery do I need for a Rado watch
The battery you need will be what is in it now. If you don't have a battery in it now you would need to know the size of the battery cavity or the movement number to determine this.
But let me warn you. Changing the battery on a Rado watch is not for an amateur. Rado glues the crystals on their watches and the way they do this with the snap on case backs 99% of the time you will break the crystal. To replace the crystal will cost you about $400+ because they won't just replace the crystal. they will force you to have the watch serviced as well. They play this game where they refuse to replace the crystal if the watch isn't serviced.
So trying to save a few dollars on a battery replacement most likely will cost you several hundred.
Consider this before you try to replace the battery.
Hope this helps,
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 11, 2009
What type of battery do i need for rado watch 15204673
Just take the watch to a local Jeweller. They keep all the batteries in stock and you won't have to buy 10. They will do it whilst you wait and charge you $6 to $8. It is not worth the aggro to do it yourself. Most watches need a tool to remove the back.
Nov 15, 2016 | Rado Watches
I need new band
If you need a new band for RADO watch, you can pop in any watch shop and choose whichever band you like. The only thing you have to remember is; get the right size. Right size for you watch is the size between lugs in millimetres. Lugs are the things where the band gets attached to the watch. Measure that distance - this is the size of band you are looking for.If you are after original Rado band, then you will have to pop into your nearest Rado dealer shop and order it. The real thing will be far more costly.
Mar 01, 2011 | Rado Diastar Classic 300M R12639023 Watch...
How do i set time and date of my rado wristewhatch?
Hi - I have a Rado Jubilee-Black Face-Lovely Dial
Problem:Time is set with a Key - Back of the watch
I have LOST this Key & need to buy or get one?
Can you please advise - rozilamohamed@yahoo.com
Many Thanks
Ms>Mohamed
Feb 23, 2011 | Rado Diastar Anatom Jubile watch
How to open rado coupole
Thank you for contacting FixYa.<br /> If you are opening up the back for the battery, I would HIGHLY recommend that you have done by a certified Rado Service center.<br /> They will test for watertightness, seal it properly, change o ring and crown. <br /> If you still want to risk doing yourself then follow these instructions:<br /> <b>Locate a very small tab (or recessed area) on the edge of the back cover</b>. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see. <br /> <li> 2<b><b class="ecxwhb">Pull out the stem, which releases the back on some watches</b>.</b> </li> <li> 3<b><b class="ecxwhb">Get a small flathead screwdriver</b> it needs to be a thin inflexible tip</b>. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips. </li> <li> 4<i><b class="ecxwhb">Very carefully</i> slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has)</b>. Do not attempt to insert the point of the knife. Use the length of the blade. </li> <li> 5<b><b class="ecxwhb">Get under the tab or recessed area</b> and gently but firmly turn the blade upward, popping the cover off</b>. </li> <li class="ecxsteps_li ecxfinal_li"> 6<b><b class="ecxwhb">When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch</b>.</b></li> <br /> <b>If you decide to send to Rado, then follow link:</b><br /> <a href="http://www.rado.com/stores_locator/default.htm?client_request_type=2">http://www.rado.com/stores_locator/default.htm?client_request_type=2</a><br />
Aug 24, 2010 | Rado Coupole R22625103 Watch for Men
Watch date has started to flash
I read through the Rado used instructions and can find no reference to date flashing being a warning of some sort, so it looks as though it has developed a fault.
Perhaps it is a low battery warning? Changing the battery might be the cheapest first step to solving the problem.
If your watch is still within warranty, the Rado should fix or replace it free of charge, if it is out of warranty then you will have to pay for any repairs.
If it is showing the correct date, then you could always live with it!
Jan 24, 2010 | Rado Watches
What type of battery do I need for a Rado watch (111.0322.3) - thank you.
Examine the markings on the battery. It is likely to be a 1.5-volt Silver Oxide or Alkaline battery. It doesn't matter which one you use, although the Silver Oxide battery can handle heavier energy-consuming loads, such as a multifunctional chronograph. It can be purchased from amazon, here: watch battery 1 5V silver oxide 357 SR44 SR44SW 10 pack. I hope this was helpful. Cheers
Simon
Nov 04, 2009 | Rado Integral R20383142 wristwatch
Feb 02, 2009 | Rado Diastar Anatom Jubile watch
Watch hands need fixing, re-oil, either watch battery or mechanism need fixing rado watch from the 80's or 90's
Jun 19, 2008 | Rado Watches
Rado watch
Sep 18, 2007 | Rado Integral R20383142 wristwatch
Watches Logo
67 people viewed this question
Top Rado Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rado Watch Expert? Answer questions, earn points and help others
