Question about GE JNM1851SMSS Convection/Microwave Oven
Profile convection- how to replace light bulb
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: GE Profile Convection/Mircowave Oven Hood
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the door switch that has gone bad and should be replaced as everything else is working fine so don’t think its fuse or anything else that has gone bad. Please do accept the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Sep 02, 2010
Changing the lamp in microwave of GE model pt970srss
If it is at all like a plain microwave oven, you will have to remove the screw for the cover to access the insides and likely will find that the light is not a simple screw-in bulb but a sealed package with a spare of spade terminals on top. It may be held in by one or more screws.
It is possible that this could be like a new conventional oven where you have to remove a light cover inside the cavity to access the bulb and change it
May 13, 2014 | GE Profile PT970 30" Built-In Double...
JVM 1790sk01
Cook using microwaves or convection in this stylish microwave oven that allows your food to be flavorful beautifully browned and cooked quickly .now your microwive didn't work .you should take it to fix .
home light bulbs
May 03, 2012 | GE Profile Spacemaker Over-the-Range...
Bought house with GE Profile Convection Oven. Do not know proper cooking directions, nor how to work many of the features. Also no light bulb in it & would like to know which one to buy. Need manual t
GE has the manuals for most of their appliances on their site: http://www.geappliances.com/service_and_support/literature/ . Just enter the model number and click Submit.
The direct link to the manual for the JVM1790 Over-the-Range Convection/Microwave oven is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40480-1.pdf . GE only lists the JVM1790CK, JVM1790BK, JVM1790WK and JVM1790SK.
I hope this helps.
Nov 10, 2011 | GE JVM1790 Convection / Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How can I replace the interior light on ge profile microwave model# jvm1790sk01?
Take the vent off of the top of convection oven, there will be two screws, then inside center front, you will find a metal box open both ends the light bulb is in there. The light you will need is a holegen 120 Volt 20 Watt they can be found at home depot. Hope this helped you
Nov 04, 2008 | Microwave Ovens
GE Profile Spacemaker Microwave
Absolutely. That's why they make shop bulbs to use in one's portable garage work light and garage door opener.
Slamming the door of a microwave is never good idea!
Another factor is touching the new bulb with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
GE JNM1851SMSS Convection/Microwave Oven Logo
26 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
