Question about Stanton STR8-30 Turntable
Do I need a pre-amp?
Does this turntable have a built-in pre-amp?
    Champion:
  • Stanton Expert
  • 271 Answers
Hi, no built in pre amp. If you are connecting to an amp without dedicated phono input you will need to use a preamp or mixer. Cheers John.
Posted on May 03, 2013
Volume from turntable too low
Have you got it connected to a dedicated "phono" sockets that has an in-built pre-amp for it?
If you haven't got one you might need a magnetic cartridge pre-amp.
If it has got a pre-amp then it's possible the pre-amp has failed. To check, remove the wires from the cartridge. And with your finger (with the unit connected to an amp and it switched on) touch the wires one at a time. You should hear a loud buzz on two of the wires. If you do the cartridge is faulty. If you don't the pre-amp has gone. The pre-amp failure will not effect any other function on the amp. Pre-amp's are these days a single IC, which will need to be replaced.
Nov 29, 2015 | Audio Players & Recorders
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Feb 24, 2015 | Technics SL-BD22 Turntable
Could I conect philips 660 turntable with receiver
As long as a Magnetic Cartridge is fitted to the deck and that the receiver has a built in pre-amp for a Magnetic Cartridge, then it will work. If the receiver does have the pre-amp you will need to purchase one separate.
Nov 16, 2014 | Audio Players & Recorders
How to connect dav-hdx 900 to turntable
Firstly, your turntable will need a phono pre-amp. This can either be built in or an external box.
Connect the pre-amp phono out to the DAVHDX900 Sat.Cable 'R audio in L' sockets.
Aug 23, 2014 | Audio Players & Recorders
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
What pre amp do i need too conect my nad L 75 to
Any that has a magnetic cartridge pre-amp built in.
Jan 31, 2014 | Technics SL-1210 Turntable
Ihve just purchased Kenwod P-110 turntable for my husband - do I need to purchase speakers also or can this be conected to TV Audio ???
Generally most turntables require a "magnetic cartridge pre-amp" before it becomes as loud as say a CD player. TV's generally again don't have pre-amps of this type built in. So unless the turntable has a pre-amp built in then any sound would be too low. Some amps don't have one built in so you need to check that too before purchasing any amp. You can buy the pre-amp seperatly too!
Dec 27, 2012 | Audio Players & Recorders
Lack of signal to amp on turntable
You need to get a pre amp for your turntable. The 5740 does not have one built in. Not to worry, they are actually inexpensive! Google pre amp or turntable pre amp & you will find lots of good units that will do the trick for 25-45. They also give you an input ground to get rid of that lovely turntable humm. Hope this helps
Jun 24, 2009 | Yamaha HTR-5740 Receiver
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
Built in Pre-Amp has gone out
Remove the turntable pad (part where the record sits) and the switch is in the corner.
Apr 03, 2008 | Audio Technica AT-PL50 Turntable
Stanton STR8-30 Turntable Logo
170 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
