Question about Maytag MAV6200 Top Load Washer
Maytag mav6200aww washing machine doesn't rinse clothes
I have a maytag mav6200aww washing machine. it stops before the rinse cycle on colors or whites. You can slam the lid and it will continue on. I read on other forums it must be the lid switch, so I replaced it. No change. you can also tap the timer knob and it will continue the cycle. some say there is a balance switch. I have not found it. thought it might be the timer, but if it was would it do it on colors and whites. thanks in advance.. Paul F.
  • 51 Answers
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Posted on Mar 13, 2009
Washing machine agitates, rinses, but does not spin
Is the motor running but the unit will not spin?
Nov 09, 2012 | Washing Machines
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Clothes look drab after washing them.
Is the machine new or old? How long has this been a problem? Has this been occuring slowly or has it started suddenly? Before you give blame to the machine, I suggest you wash your clothes at a laundromat or a friend/relative washing machine to see the results you get. Also, the detergent could be partially at fault especially if you use too little or too much (too much will cause a film to build-up on the clothes that cannot be washed away enough durung rinse). IF AFTER TRYING THESE SUGGESTIONS YOU STILL HAVE THE PROBLEM, open the lid while your Maytag is washing to see if the water level is sufficient and to see if the aggitator is moving; note- you may have to open quickly and check very fast to see if there is aggitation movement because some models stop the washing if you open lid (all models stop the rinse/spin action if you open lid.Goodluck, Macgivor
Nov 09, 2009 | Maytag HAV2557 Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
366 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
