Question about Microwave Ovens
Amana oven shuts off
Goes dead randomly after heating up
  • Microwave Ovens Master
  • 9,085 Answers
First you need to be sure the internal cooling fan is running and your air flow is not blocked.
The cooling fan should run anytime you are cooking.
If not, the magnetron will overheat and its thermostat will open, disconnecting power to the unit until it cools off and resets.
If that's not the issue, then you either have a bad connection or a bad magnetron.
You can find exploded views and manuals here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=***&siteCd=WHRCOM&userType=Consumer
NOTE: On the resulting page, you will need to enter your full model number from the tag on or in the unit.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 04, 2013
Amana RS10D Not heating up . Fuse,2 thermal cut out, door switch, all ok. board/ magnetron/ transformer dead? Pls help. Don't want to discard 5 units...all same problem...Thanks
I regularly repair Amana commercial microwave ovens.
  • What is the FCC ID number from the tag?
  • What is the Manufacturing number (like P76695, etc.)?
  • Is it making any unusual noises?
  • Is it running quieter or louder than usual?
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 11, 2017 | Amana Microwave Ovens
Amana ACM2160A 1100 Watts Microwave oven doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
56ik
May 13, 2010 | Amana ACM2160A Microwave Oven
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
Sep 12, 2009 | Sharp R-1850A Convection/Microwave Oven
OTR Amana microwave- No power, lights, clock or sounds.
Either your magnetron, cooling fan, or the magnetron thermostat is failing.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Amana / Whirlpool customer service is here.
Please contact them to find your nearest authorized service center.
Jun 06, 2009 | Amana Radarange Microwave Oven
Abnormal noise produce by Amana microwave RC17
Deart Customer
please undergo the following
Since 30 to 50 percent of the power into a microwave oven is dissipated as heat in the Magnetron, cooling is extremely important. Always inspect the cooling fan/motor for dust and dirt and lubricate if necessary. A couple of drops of electric motor oil or 3-in-One will go a long way. If there are any belts, inspect for deterioration and replace if necessary.
An oven that shuts off after a few minutes of operation could have a cooling problem, a defective overtemperature thermostat, a bad magnetron, or is being operated from very high AC line voltage increasing power to the oven. One interesting note: Since 30 to 50 percent of the power goes out the vents in the back as heat, a microwave oven is really only more efficient than conventional means such as a stovetop or gas or electric oven for heating small quantities of anything. With a normal oven or stovetop, wasted energy goes into heating the pot or oven, the air, and so on. However, this is relatively independent of the quantity of food and may be considered to be a fixed overhead. Therefore, there is a crossover point beyond which it is more efficient to use conventional heat than high tech microwaves
i think the information would help u if so rate me please,otherwise just give it as fixya,Thank u
Dec 17, 2008 | Amana RC17 Microwave Oven
Amana micorwave
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Emerson MW8108P Microwave Oven
Blown fuses
I service a lot of commercial units.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Please feel free to contact me directly if you need more help. If you can scan and e-mail the mini-manual, that would help me help you, too.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Amana HDC21 Microwave Oven
Amana Microwave Problem
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Mar 18, 2008 | Microwave Ovens
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
