Question about Pool & Spa
How to fix pool pump
Make alot noice
  • 7,482 Answers
Hi fu xing
It is probably making all the noise because of faulty bearings.
Replace the noisy bearing with new ones and that will solve your noise problem
Bud
Posted on Apr 25, 2013
How to stop the noice
what kind of noise is it making? is there water in the pump?
Apr 25, 2013 | Hayward 2HP Pool Pump Motor A O Smith...
How to stop motor make noice
replace the bearing...they are the noise makers
Apr 25, 2013 | Hayward Pool & Spa
Broadcast yourself you tube
replace your bearings..they are the source of your noise
Steering Wheel noises
What kind of noice are we talking about. If it is a wining noice it could be the power stearing pump but if it is a grinding noice it would be best to change the whole column it will save you alot of headache.
Feb 25, 2013 | Cars & Trucks
Sundance high speed pump shuts off
Is this over heating? If it is overheating and shutting down it will come back on once it has cooled down.
the issue may be bad windings or bearings in the motor. Is it making any noices while it is running?
This is something that needs to be fixed right away. You can either purchase new motor for it or have it taken to a motor shop locally and have them fix the motor.
Rod
US Parts Center
Feb 04, 2013 | Pool & Spa
I had my pool opened today, but the pump wont start. It makes no noice at all. Checked brakers. Don"t know what else to do. It worked foine up until closing last year. ???
There are several things that you will want to check to find out why Hayward sand pool filters are not operating correctly. Try to get the filter to backwash. Make sure that the multi-port valve is not broken or damaged in any way. Check the skimmer and pump strainer baskets for debris. Check for air leaks in the intake line (indicated by bubbles returning to the pool). If none of this is the case, you need to have an electrician check your connection. Even if it appears that your breaker is working, it sounds like you have a faulty electrical connection that should be handled by a professional.
May 10, 2011 | Hayward SAND FILTER, PRO SERIES
I put pool on an timer after pool has been off for an hr will not get its prime back. I have alot of agiation in pump skimmer basket when running and alot of air and bubbles returning to pool I also think...
You have a massive air leak either in the pump or going to the pump, that you will need to dig around and look for, A cheaper solution is to try to find a used pump, buy it and see if it make any difference. There is also a main seal in the that is sometimes bad or is not set right that can be replace or repaired REALLY easily
May 04, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pump making a louder than normal noice and seems to be grindng a bit. Also getting some leakage in the area where the pump shaft enter into the housing.
You have a bad pump seal. The water now entered the motor and ruined the motor bearings. Time to replace the motor and pump seal. If it is an old pump I would suggest replacing the whole thing.
Aug 30, 2009 | Pool & Spa
Noisy pool hayward pump
Dont run pump any longer. Could damage it further. Recommend overhaul at qualified well established pool repair shop. If unset of noise suden probally somethign stuck. If onset of noise gradual probally bearing. Kirk
Feb 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
52 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
