Question about Car Audio & Video
Sounds like a rainstorm
I have a 12" kicker comp set up with a sosche 300 watt amplifier. I have the power and the audio cables ran correctly, but the sub sounds like a rainstorm with the music playing. Any help? Also when i turn off my car i hear a popping noise.
  • cszero Mar 13, 2009
    it also doesn't sound loud enough even though i have it turned all the way up. any ideas?
    Problem Solver:
  • 17 Answers
I had the same problem when i hooked up my memphis 500. i called the local audio store and they told me to make sure i had a good ground wire and keep the power and the remote wire away from each other. if they are to close they cause interference making the whining and popping noises. running your power and remote wires on opposite sides is what i had to do.
Posted on Mar 13, 2009
  • Michael Mitchell
    Michael Mitchell Mar 14, 2009
    Try switching you RCA's and if that doesn't work try a heavier set.
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
I have a comp s 12 2ohm kicker and a comp vr 12 dual 2ohm kicker how do i wire these to stay at 2ohms to the amp
you can wire them to be at 2ohm load you need two of the same speaker. its is very bad on the amp to run like that and you will not get a good bass sound because one will over power the other sound wise
Mar 23, 2013 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I have 2 10" Kicker Comp Subs
That amplifier is only rated at 150 watts at 4 ohms, or 300 watts at 2 ohms. Not a very strong amp to run 2 kicker comps. My guess is you have the subs wired wrong for your application. There are 2 types of subs, one is a dual 4 ohm, and one is a dual 2 ohm. Most people bridge these coils together and that cuts your ohms in half. For example. Lets say you have the 10cvr104 subs. Thats the dual 4 ohm sub. You wire the coils together in parallel, now its a 2 ohm sub. You have 2 of these subs running off of your amp, if they are hooked up in parallel, now you have a 1 ohm load, out of the amplifiers normal operation. Your amplifiers internals heat up really quick and there is a thermal overload, putting your amplifier into circuit protection mode. My suggestion for wiring your subs is as follows: for each speaker, wire the coils together like this- positive coil1 to negative coil 2 and negative coil 1 to positive coil 2. That is called running in series, and doubles your ohm load. Next, we need to wire the speakers together properly to hook up to your amplifier. For this, since the coils are hooked together, you only need to use one set of terminals from each sub. And take the positive from sub 1 and hook it to positive of amp. Take negative sub 1 and hook it to positive of sub 2. Take negative of sub 2 and hook it to negative of amp.
Aug 30, 2012 | Rockford Fosgate Punch 301M Car Audio...
How many watts are in the kicker comp zr600 amp? i was told that it was a 1000 watt amp. i just want to make sure that it is a 1000 watt amp and not a 600 watt amp. i am powering two 15'' kicker comp subs...
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
Feb 05, 2010 | Kicker ZR600 Car Audio Amplifier
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
Your amp
Do you have a remote wire set up? if not, you need to run one from your deck so that it can trigger the amp to come on.
May 14, 2008 | Kicker ZR360 Car Audio Amplifier
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Apr 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Digital audio dhc 2754
no thay need 1000 rms each i would go with a hifonics bxi2010d amp from for around $300
Mar 26, 2008 | Digital Audio 1000 WATTS HIGH CURRENT...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
