Question about Polaris Pb4 - 60 Booster Pump
Water Flow to Booster Pump
Bought replacement booster pump and can't figure out how to stop water flow to existing pump. Water continues to flow out drain plug after I remove it.
  • Polaris Master
  • 1,383 Answers
Plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Posted on Mar 13, 2014
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Posted on Apr 29, 2009
john224
  • 1378 Answers
SOURCE: when running it makes a loud continuous loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Posted on Aug 24, 2009
john224
  • 1378 Answers
SOURCE: my pb4 booster pump is leaking from the booster
Replacing the pumps mechanical seal should fix the leak. The whinning may be from bearing damage due to the leak. If you are unsure how to fix it, try a local electric motor repair shop. We charge about $55 - $60 for that seal and bearings installed.
Posted on Aug 27, 2009
  • 16 Answers
SOURCE: I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Posted on Jan 16, 2010
Booster pumps
Make sure the main pump is running while the booster is and make sure there is no air in the lines. You may have to open the pump to see if any debris has gotten into the impeller.
Aug 05, 2013 | AO Smith Pool & Spa
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
I hooked up a new Polaris 280 pool cleaner to replace my Arneson Navigator and it doesn't move.
I would first take it out of the water and check for proper wheel RPM. If it is less than 28 RPM or you are getting no movement at all, it is going to be a problem with the power source. It is likely going to be that your booster pump is missing, malfunctioning, or is not installed properly on the pool cleaner. There are a few other things to check. Clean the skimmer, filter and pump basket, clearing any debris that restricts water flow. Check the hoses, connections and swivels for leaks. Try removing the blue restrictor disk from the UWF or if an adjustable gate valve is installed on the booster pump or cleaner line, open it completely so water can flow freely.
Jul 20, 2011 | Polaris VacSweep 280 Pool Cleaner with...
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
New installation. water flows correctly with main pump on and working. when booster turned on, motor runs seemingly normally but water flow to sweep is blocked entirely.
Inside the wall you have a screen that may be plugged. remove the hose from the wall and the fitting will have the screen inside it.
Jun 24, 2010 | Hayward .75 HP Booster Pump
Motor on reverse osmosis runs constantly
If this is a booster pump, many booster pumps like Shurflo have an adjustment at the top (allen screw) to back off on the pump pressure, turn to left to back off on pressure. If it never shuts off this can be an indication of a bad membrane, capillary tube, flow restrictor or automatic shutoff, causing all the water to run to drain. If you have low quantities of water, but pump always runs, this could part of the problem. Also high TDS (total dissolved solids) will cause the pump to work more. The higher the TDS 500+ppm the harder it is to produce quality water. With high TDS it's almost like taking muddy water, running it through filters and getting drinkable water. So the RO and pump have to work much harder to produce any quantity and quality of water.
RJ
May 01, 2010 | Culligan Under Sink Water Filter
My booster pump only starts intermittently. It sometimes only runs for a minute or two before shutting down. Other times it will run all day The water flow seems a little low when running. Power is...
Your best solution is to take it to a local small motor repair shop and have it rebuilt for under $100. Replacement is about $300. There is almost nothing you can do on your own... Sorry
Mar 07, 2010 | Polaris Pb460 Polaris Booster Pump...
Polaris booster pump runs for minute but quits. Tries to restart
Aug 24, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris booster pump turns on for about 3 seconds. then its pops off. but it doesn't trip breaker and in about one or two minutes you can hear it click and reset itself. you can then turn it on and it will...
That click you hear is the pump's breaker, or thermal overload kicking in. After about one minute, the pump has cooled down again.
I believe this type of pump is not self-priming, and therefore, it needs to be primed and purged of air. If it is not a self priming pump, there should be a small plug on top of the pump housing. Remove the plug, and add water from the top opening until the water overflows, and then replace the plug. Or, if when you remove the plug, water comes out the top opening, let it flow for a few seconds, and then replace the plug.Then, turn the pump on.
Hope this was helpful...
Jun 23, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris 280 flow is low and moving slowly with nosedive mnmc660 yahoo com is my email. seems like tale spray is fine but rear spray output and wheels turn slow resulting in nosedive. alkready checked...
Make sure that your skimmer, pump, and pool filter are clean and working properly. Your automatic pool cleaner can become sluggish if anyone of these features of your pool is not working correctly. Check all the hoses, connections, and swivels for leaks that could cause loss of water pressure. If it has been working poorly since you replaced the booster pump, you will also want to make sure that it is installed correctly. Finally, check your wheel RPM. It should be operating at between 28-32 RPMs. To do this, mark a single wheel side tire. Turn your pump on, hold the cleaner underwater and count the wheel revolutions for one minute. If you are under 28 RPMs, this might be your problem. To correct this, check your filter screen. I know thay you said that you have already done this, but this is typically the problem so I would check it again. Also, you can remove the blue restrictor disk from the UWF. If you booster pump has an open gate valve, open it completely to increase water flow. This will also help with your RPMs. If you try these suggestions and they do not work, let me know and I will come up with something else to try. Hope this helps you out.
Jun 06, 2009 | Polaris Vac Sweep_ 280 Pressure Side In...
Polaris Pb4 - 60 Booster Pump Logo
110 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
