Question about Hayward Pool & Spa
How to stop motor make noice
Model ; c48k2n143a3 hp1 typeuac
  • 7,482 Answers
Replace the bearing...they are the noise makers
Posted on Apr 25, 2013
2005 mazda4cycl over head cam knocking noice like a lifter noise or bent rod when reving but noice cycles knocks a minute an stops for a minute an starts and stops
Hi Troy I owned a motor bike years ago and I had the same problem, It would start off with a quiet knocking sound and get louder then suddenly stop but start up quietly again and again and so on which turned out to be the timing chain was worn.... SERIOUS mate. Good luck......
Apr 17, 2016 | Cars & Trucks
GE electric Dryer model GDX8060SW will not start, makes a humming noice only. Exhaust duct was clogged with lint, which I removed. Still only humming noice when trying to start Dryer. Is there a reset...
could have a jam still in the blower wheel and all...sounds like unit is getting power and trying to start if your getting a hmm but something is keeping it from turning...gain access to the blower area and check a little deeper for more obstruction...aso make sure belt did not come off of motor maybe motor is humming but not turning unit....
Jan 03, 2011 | Dryers
My electric motor went bad and i am trying to replace it but can't remove it from the pump housing
you do not want to replace the motor only, the pump is handled as a unit... there are seal issues, etc.
Sep 05, 2010 | Jacuzzi Magnum Force Series Pool Pump 1...
How i can connect electric motor in to air compressor 230 volt hp7.5 hp1
A motor like that will require a motor starter, you cannot use just a pressure switch cause it draws to many amp's
Jan 29, 2010 | Ingersoll Rand DD2T2 T Win Stack Single...
We have one of your walk in freezers. One of the inside fan motors quit working. It is a Fasco motor mod-71639383---type-u63---1550 rpms---hp1/20. Do you have it? DooLittles Restaurant--Arnie Jennings/...
Fasco makes bunches of these types of motors. Call Rick at Restaurant Parts and More. Have motor in hand and I'll bet he can match it with one of the Fasco "Over the counter" type motors. I use them all the time and am very successful with them.
1-888-814-1110.
Jan 18, 2010 | Freezers
Grinding noice when printing
Most likely problem is the Fixer Gear, seems to be an issue with these printers. Part number is LJ7416001 but does not look to be the easiest to Replace
Apr 29, 2009 | Brother HL 5170DN Laser Printer
Plate does not rotate freely and make noice
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
