Question about Frigidaire Microwave Ovens
Screw size part number: 316545301
  • Frigidaire Master
  • 9,047 Answers
316545301 is the part number of a door handle.
That handle fits more than one model, and the in manual I looked at that had that handle, the dimensions of the screws were not described.
So you would have to look up the screws by part number in the appropriate exploded view for your specific model.
Replace the XXX in the URL below with your full model number from the tag in
or on your unit, or simply click the link and enter your full model number on
the resulting page.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KHMS155LSS3&siteCd=WHRCOM&userType=Consumer
You can order parts from the Pros here.
Posted on May 04, 2013
THE SCREWS ARE VERY VERY SMALL....HOW DO YOU FIGURE OUT WHAT SIZE STAR SCREWDRIVER TO USE??
It would be helpful to know your brand and model and what you're trying to do.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 18, 2017 | Microwave Ovens
How to change a lightbulb in a GE JNM1541
You will need to remove all the screws and the wrap around the microwave, the outer cover is the metal wrap around, to access and replace the cavity lamp. Manufacturer part number is WB36X10131 and GE part number is AP2030108. The screwdriver needed is a Torx Tamper Proof Screwdriver and it should be size T20H. 56912B in the diagram shows the bulb and its location.Not an easy job, but definitely cheaper than paying GE $200.
Sep 23, 2015 | GE Microwave Ovens
I have an atlas waldorf wall oven which has a blown light bulb. Can i fix it myself or do i have to call the pros.to fix it?
isolate the supply to the oven
remove the lights panel screws and unscrew or rotate the bulb
look at its number they are usually a standard size of screw in
but its an OVEN BULB and it is treated glass !!!
and must !! be this type or it will pop quite quick and loud
the local hardware shop will have them i get them for 1 pound for 2 local
screw in a new bulb but use a bit of tissue to hold it dont touch it with your hands
fix the panel back on and test
its an easy job you can do yourself
Aug 13, 2014 | Microwave Ovens
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
We need a replacement screw bolt for our meat slicer model number KS700B how do we get one?
The hardware stores carry a large selection of screw bolts and nuts, I would imagine they would have the size you are looking for, Lowe's has a huge inventory of all kinds, depending where you live will determine availability.
Mar 12, 2011 | Microwave Ovens
My lower hing screw has fallen out, how do I replace it and with what typs of screw?
That is a bit tricky, because if the hinge is allowed to get loose, microwave energy leakage can occur, which can lead to arcing and possible fire.
I would say to pull out the remaining screw and match it up at a hardware store, but that may make the hinge too loose to stay in place.
So only do that if you can totally immobilize the door. Duct tape comes to mind.... ;)
One other option is to try a few different sizes in the open hole without removing the remaining screw.
Try 6-32, 8-32, and 10-24 by about 1/4" to 1/2" long. You may also want to try similar metric sizes. When you find one that fits, you can apply some Loctite, insert it fully. Then remove, Loctite and reinsert the remaining screw. If you want, you can use nail polish instead of Loctite.
The three service manuals that cover these models are here, but they don't have part numbers for the screws:
http://www.microwavedisplay.com/BLMV169_GLMV169_PLMVZ169GCB_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
Jan 01, 2011 | Frigidaire GLMV169 Microwave Oven
I have an older kitchenaid 30-inch cooktop - Model number KGCS100S. I want to replace it and need to know the size of the existing cut-out. I can't get a measurement without a lot of extra work and...
Hello
Unfortunately, the cooktop you have is no longer in production, and even if i give you the dimensions of the cooktop, the cut - out is not a standard size, some people like to make a more spacious cut - out, where others give it a tight fit.
Best way of knowing is to unscrew the screws and lift out the top and measure the dimensions yourself.
I really hope this can be of help, please do not hesitate to let me know if you have any further questions.
Kind regards
Andrea
Jun 17, 2010 | Microwave Ovens
Need installation bracket screws
You'll probably be able to find the part number either from the installation instructions. You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 14, 2009 | GE Microwave Ovens
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
Apr 05, 2009 | GE Microwave Ovens
Special screw on case & main fuse
You can remove the anti-tamper screws using using a T20H Torx type or GTXH20-100 screwdriver.
If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
You can find helpful exploded view diagrams and get part numbers by entering your full model number here.
Once you have part numbers, you can find parts at a better price
here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit, such as behind the control panel or hidden elsewhere, which is very helpful when troubleshooting, testing, and locating components.
Dec 26, 2008 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
29 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
