Question about Tti Hoover F7412-900 Max Extract Dual V WidePath Carpet Cleaner
Brushes not rotating
Brushes will not rotate
  • Tti Master
  • 18,408 Answers
Here is manual > http://hoover.com/file/593/
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaningbrushes not rotating - icon1.png has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plasticlb_icon1.png has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this femaleicon1.png receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the
number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair...
Posted on Apr 25, 2013
Why does the rotating brush not work ?
Check to make sure rotating brush is turned on and check for broken or worn belt
Sep 02, 2014 | Electrolux Vacuums
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Belt not broken.... brushes will not rotate.
most have two belts, brush roll rotates only when head is level with the floor....
Feb 19, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
May 17, 2008 | Vacuums
Tti Hoover F7412-900 Max Extract Dual V WidePath Carpet Cleaner Logo
124 people viewed this question
Top Tti Vacuums Experts
JoeVacs
Are you a Tti Vacuum Expert? Answer questions, earn points and help others
