Question about Ferret Instruments GasLink II 5-Gas Analyzer - FER16
Freeses same ceroingz gas detector lee phane 1 minuto remainig
    Welcome Back:
    Visited the website for 2 consecutive days.
Any time you have any troubles with your Ferret Instrument products, please call our Repair Department at
800-627-5655 x 101. They will be very happy to assist you.
Our Hours of Operation are Monday - Thursday, 7:00am-4:00pm EST.
Posted on Mar 08, 2016
    Problem Solver:
  • 18 Answers
The phone number is 800-627-5655 Chris and Evy run the repair dept.
The zeroing problem is a in a lock up state. really need to call in this situation
Posted on Jan 26, 2015
How does a gas detector work?
work by signifying high levels of gases through a series of audible or visible indicators, such as alarms, lights or a combination of signals. While many of the older, standard gas detector units were originally fabricated to detect one gas, modern multifunctional or multi-gas devices are capable of detecting several gases at once. Some detectors may be utilized as individual units to monitor small workspace areas, or units can be combined or linked together to create a protection system.
Read more here: http://www.thomasnet.com/articles/instruments-controls/How-Gas-Detectors-Work
Jan 30, 2013 | Measuring Tools & Sensors
We cannot get any lp to any appliances
Obviously the detector must be faulty, or bad connection from detector to gas valve on system. You'll have a power wire coming in to back of detector that you need to attach directly to wire going to gas valve in line near connection at tank. Use a continuity tester/multimeter to determine which wire. Check all connections at back of propane detector and make sure power to it, before resorting to direct connection temporarily until detector can be replaced. Should have power in only on one wire when off, and power at other wire(s) except ground when turned on. That wire will be (should be) the one going to gas valve near tank.
Sep 05, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
La maquina cuando esta lavando sale f21 y no escurre el agua
F21 DRENAJE DE LARGO
Si el tiempo de drenaje supera los 8 minutos, el apagar las v?lvulas de agua.
NOTAS: Despu?s de 4 minutos, el "SD" error se mostrar?, a continuaci?n,
4 minutos m?s tarde el "F/21" c?digo de error se mostrar?. Pulse
PAUSA / CANCELAR dos veces para borrar la pantalla.
Posibles causas / Procedimiento
1. Revise el tubo de descarga y aseg?rese de que no est? conectado o
doblada.
2. Desenchufe la lavadora o desconecte la energ?a.
3. Compruebe las conexiones el?ctricas en la bomba y aseg?rese de
la bomba est? funcionando.
4. Compruebe la bomba de drenaje de objetos extra?os.
5. Enchufe la lavadora o reconecte el suministro de energ?a.
Dec 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No voice
call cobra 773 889 3087 the speakers are a few dollars and just plug in
i have replaced the speakers in both of my detectors they usually only last about 1 1/2 years
May 05, 2010 | XRS 9700 Radar Detector
Periodically emits 3 loud beeps. Displays 888.
The CO detectors require replacement of the battery periodically.
Unlike smoke detectors, the detector element itself also requires replacement as well as the battery and is sold as a module with the battery attached.
May 02, 2010 | Kidde Nighthawk Combo Gas/co Detector
What does code 222 and 224 mean on the kidde nighthawk combo gas/co detector?
was there also an alarm with that reading? Normally it would suggest gas leak.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 03, 2010 | Kidde Nighthawk Combo Gas/co Detector
What do codes 222 and 224 mean on co detector
Hi there.
Did the alarm also go off? Cause that normally means a gas leak.
Cheers
TeaCii
British gas carbon monoxide detector problem
If it is beeping 3 beeps every minute it is at the end of its battery life you can just replace the batteries by prising the cover off carefully.be aware though that the life span guarantee of these is only 5 years.
Dec 13, 2009 | Kitchen Appliances - Others
We have a combination carbon monoxide/gas alarm and the gas alarm went off. We are having a girls party and it is in the basement and they are using nail polish and nail polish remover, some of it spilled...
This is normal your detector is sensing particles in the air.
Also You should never buy a duel detector. Because if one becomes
defective you loose protection from both detectors. It is recommended
to use two separate detectors, because different detectors are installed at different heights in the house. Not all gases are the same weight.
Also carbon or gas detectors should be replaced every five years. and smoke detectors every 10 years.
Sep 06, 2009 | Kidde Nighthawk Combo Gas/co Detector
Ferret Instruments GasLink II 5-Gas Analyzer - FER16 Logo
431 people viewed this question
Top Ferret Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ferret Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
