Question about Fantom Drives Databank 64gb Usb 2.0 Flash Drive
My FANTOM 16GB DATA BANK devoloped a write-protect stage that contains a Application File 'System Volume Information .exe in it. How can I re-format it to make it functional?
All conventional methosd of re-formating failed. Anybody out there with a solution?
Tip
How to Use Qfixapp.exe In Windows XP
This article describes the Quick Fix utility (Qfixapp.exe) that is included with the Application Compatibility Toolkit for Windows XP and Windows .NET. Qfixapp.exe is a tool that includes pre-packaged fixes that provide an easy way to fix a program.
Use Qfixapp.exe To Apply Program Fixes
You can use Qfixapp.exe to quickly apply various program fixes (AppFixes, also known as "shims") to a program to determine their effectiveness. Qfixapp.exe reads the %SystemRoot%\windows\apppatch\sysmain.sdb database to produce a list of available fixes. When you select an AppFix, you can start the program executable (.exe) file, and the AppFix will be applied. If a suitable AppFix is found, the tool eventually helps you to generate and test matching file information. When you run Qfixapp.exe, you see the following items:
  • The The application for which to apply the fix(es) check box. This setting disables existing fixes in the database.
  • The Layer tab with the Choose one of the existing layers to apply to your app box that contains the following entries:
    256 Color
    640X480
    Disable Themes
    Internaltional
    LUA(Limited User Account)
    LUACleanUp
    NT4SP5
    ProfilesSetup
    Win2000
    Win95
    Win98
  • The Fixes tab. On this tab you can select the individual fixes that you want to apply.
Example of How to Use Qfixapp.exe 1. Start Notepad, and then click About Notepad on the Help menu. Note that the version is 5.1.
2. Start Qfixapp.exe, click Win95, click Browse, and then open the Windows folder. Note that the Windows\System32 folder is protected by Windows File Protection, so it is not able to use the layers.
3. Click Notepad.exe, click Open, and then click Run.
4. Start Notepad, and then click About Notepad on the Help menu. Note that the version is now 4.0.
If you click ViewLog, you could see what AppFix(es) are being used. If you click Advanced, you could see information about the .exe file. You can click Add Matching Info, and then select files that are related to the .exe file to identify that particular program. After you finish that step, you could click Create Fix Support to add the layers with the Matching Information (GRABMI) and create an XML-based database that is named YourAppName.sdb. Note that in the preceding example it is named Notepad.sdb, and is in the AppPatch folder.
on Jul 03, 2010 | Computers & Internet
Problem with Rise & Fall: Civilizations At War for Windows 7. how to open ebooklibrary.exe
To install and run "R&F Civilizations at War" in Windows 7:
1) Run the Setup file and install the game
2) Google and download "http://www.ausgamers.com/files/process/24085/rise-and-fall-civilizations-at-war-patch-v115-beta" and "http://www.star-force.com/support/sfdrvup.zip".
3) Install "Rise and Fall: Civilizations at War Patch v1.15 beta".
4) Run the game, let it install required libraries and then reboot.
5)Run sfdrvup.exe and update the protection driver. Reboot.
Now the game should run in Windows 7.
Jan 08, 2012 | Computers & Internet
The Dorkbot.A worm changed my files into TMP files, ESET NOD32 cleaned the virus. How do I restore the TMP files to my files and folders?
The hard drive was corrupted but the worm virus. Worms will eat data and can change the data to what it wants (to destroy anything). If you can not do an open with to open your data with the correct program.
Dec 12, 2011 | Western Digital My Passport Essential...
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
Problem Event Name: APPCRASH Application
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Dec 09, 2009 | Yahoo Messenger
I would like to know why I continually lose connection while playing YoVille game on Facebook? I'm usually in the middle of a game, and it says I need to refresh, which causes me to loose coins. I asked...
The free file information forum can help you find out if csrcs.exe is a virus, trojan, spyware, adware which you can remove, or a file belonging to a Windows system or an application you can trust.
csrcs.exe file information
The process belongs to the software CSRCS.EXE by unknown.
Description: File csrcs.exe is located in the folder C:WindowsSystem32.
Program has no file description. The program is not visible. The file is located in the Windows folder, but it is not a Windows core file. HKEY_CURRENT_USERSOFTWAREMicrosoftWindowsCurrentVersionRunOnce, HKEY_USERS.DEFAULTSoftwareMicrosoftWindowsCurrentVersionRunonce).
It is not a Windows system file. Program listens for or sends data on open ports to LAN or Internet. csrcs.exe is able to hide itself, monitor applications. Therefore the technical security rating is 100% dangerous.
Important: Some malware camouflage themselves as csrcs.exe, particularly if they are located in c:windows or c:windowssystem32 folder. Thus check the csrcs.exe process on your pc whether it is pest. We recommend Security Task Manager:
http://www.neuber.com/taskmanager/index.html?ref=file.net
for verifying your computer's security.
If this information is useful, please mark as helpful. Thanks
Oct 03, 2009 | Microsoft Windows XP Home Edition
I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
Jan 10, 2009 | Computers & Internet
System says that program not responding
From what you put on this, it seems that you have a KERNAL32 error.
Fault Module Name: kernel32.dll
the application being Windows Media Player
Application Name: wmplayer.exe
I've researched this thru microsoft and the best thing I can find
Go to Start - > Type Run in the Search Box - > type regsvr32wmp.dll
What operating system are you using? Because the KERNEL32.DLL file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (ME).
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Fantom Drives Databank 64gb Usb 2.0 Flash Drive Logo
80 people viewed this question
Top Fantom Drives Computers & Internet Experts
micky dee
Terry Hair
Are you a Fantom Drives Computer and Internet Expert? Answer questions, earn points and help others
