How To Remove Battery - Computers & Internet
    Problem Solver:
  • 19 Answers
Hi read the Manual you have recieved with Laptop while you made purchase and then follow the steps to remove battery.
Do not follow any post as solution to remove your batter.
That is your Laptop and you purchased. No one will pay you for if laptop got damage.
Posted on Apr 26, 2013
Remove battery
  1. If equipped with power seats, move the seat to the most forward and upright position.
  2. If equipped with manual seats, move the seat to the most forward position.
  3. Turn the ignition switch to the Off position. Be certain that all electrical accessories are turned off.
  4. Remove the battery cover (1).
  5. Remove the negative battery cable (1) from the battery.
  6. Disconnect the positive battery cable and position aside.
  7. Remove battery thermal blanket.
    1. Remove the battery hold down retainers (2) and remove the battery hold down (1).
    WARNING: Wear a suitable pair of rubber gloves when removing a battery by hand. Safety glasses should also be worn. If the battery is cracked or leaking, the electrolyte can burn the skin and eyes.
    1. Remove the battery from the vehicle.
Jul 12, 2013 | 2012 Jeep Grand Cherokee
How to remove starter motor
REMOVAL
1. Disconnect battery terminals
2. Remove bolt and battery clamp
3. Remove battery
4. Clean battery tray
5. If equipped with cruise control, disconnect multiplug and hose from cruise control vacuum pump.
6. Release harness clips from battery carrier
7. Remove 4 bolts and remove battery carrier.
8. Remove battery carrier and cruise control vacuum pump (if equipped).
9. Release starter motor solenoid terminal cover.
10. Remove nut securing battery lead to solenoid and disconnect battery lead
11. Disconnect Lucar connector from starter solenoid.
12. Remove 3 bolts securing starter motor to gear box. Note that the left hand bolt also secures the mounting bracket for the Crankshaft Position (CKP) sensor multiplug.
13. Maneuver and remove starter motor from vehicle.
INSTALLATION
1. Clean the starter motor mating face on the gear box.
2. Install the starter motor by reversing the procedure in the removal instructions.
3. Before connecting the battery, clean the cable terminals and the battery posts.
4. Apply a thin coat of petroleum jelly or dielectric grese to battery terminals after connecting.
Dec 14, 2011 | 2002 Land Rover Freelander
Replace battery
Remove the negative cable end from the battery. Remove the positive cable end from the battery. Remove the hold down bolt from the front of the battery hold down. Loosen the rear battery hold down nut and remove the battery hold down. Remove the battery. Reverse this order to reinstall.
Sep 25, 2011 | 2001 Toyota Camry
Remove battery from 2002 dyna
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove the upper rear bolt, and swing down the battery box.
5. Remove the top cover, nad side cover.
6. Lift battery out, and remove negative cable from battery.
Feb 05, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
How do I remove the battery from a 2006 Dodge Durango?
One side of that battery will have a single 13 mm bolt that you can loosen and or remove entirely to allow you to remove that battery. Screws located down near the bottom of the battery.
The fender is on the left and then the battery and then the wedge is on the battery side which faces the engine. You need to remove it with a socket and long extension.
Remove the negative battery and place it out of the way then remove the positive cable and move it as well.Remove the heat guard or shield which surrounds the battery if installed.Remove the battery hold down wedge by unscrewing the bolt.Lift out the battery.Reverse for installation.--------------- Thank you.
Jan 31, 2011 | 2006 Dodge Durango
How to get to battery to change it
1. Remove the seat.
4. Remove hte upper rear bolt, and swing down the battery box.
Jan 20, 2011 | Harley Davidson FLHTCUI Electra Glide...
How do i take off the battery cover
1. Remove the seat.
5. Remove the top cover, and side cover.
Jan 17, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
I need to replace the battery. How do I do this?
Hi!!
The battery is located in the fender, ahead of the right front tire. Te battery can be removed without reovint the tire, but removing it improves access.
Here is how to remove/replace the battery
Disconnect battery cables, negative first, then positive from remote terminals.
Remove air filter housing
Remove the two battery hold down clamp bolts and clamp.
Loosen right front tire lug nuts, rise the vehicle, support it w/jackstand and remove wheel.
Remove battery cover/splash shield from wheel well
Slide battery toward rear of vehicle and disconnect battery cables.
Remove old battery thru wheel opening and insert new one.
If helpful, click below
Apr 13, 2010 | 2003 Chrysler Concorde
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the positive battery cable
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
Battery removal
The battery is located under the right front fender behind the tire. Remove the wheel, remove access panel from fender well. From engine compartment, remove 2 battery hold down bolts,10mm, slide battery rearward to remove battery cables.
Oct 18, 2008 | 2003 Chrysler Concorde
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
