Question about GE ZV750SY Kitchen Hood
I'm tired of cleaning the oily mess (not that oily but enough to be disturbing) on my GE monogram range hood european style filters. i took the screen out and cleaned them with a scunzi steamer but not able to totally clean out. can i sub disposable filters in its place so i can just throw out the filters periodically or when they are dirty? or how can i get the oil out? thanks
    President:
  • 2,992 Answers
My suggestion would be to get a good heavy-duty degreaser (Gunk Engine-Brite, maybe, from an auto parts place, or see what Home Depot has to offer) and put enough into a tub to cover the filters. Toss 'em in and let them soak. Then hose them off. Repeat this a couple of times with fresh degreaser and those filters should clean up pretty well. You might also try checking with appliance parts stores about some kind of disposable replacement, but using the permanent ones and using the degrease occasionally would probably be chaper in the long run.
Posted on Mar 13, 2009
Diagrams monogram zv750s
Go to the G.E. Website and the diagrams there.
Jul 06, 2014 | General Electric GE Monogram 36""...
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
Where is the fuse located in a ge monogram hood ZV750SY4SS?
there is a black electrical connection box inside the hood which contains the electrical feed, connections and the fuse which is a WB02X10584, rated 8A 250V. Remove the fuse, take a look to see if it is good [wire still intact] or check it for continuity and reinstall it if is good. Just removing it and reinstalling it is usually enough to have it work. regards, Joe
PS please rate my answer. Thank you.
Jan 16, 2010 | GE ZV750SY Kitchen Hood
Where can I find the internal fuse on the GE Monogram Hood model ZV950SDSS?
There are (2) inline 5A - 125V fuses under the top fan/duct cover. They are located on the left side (as facing the unit) in a plastic junction box. Four Phillips head screws hold the cover on.
Dec 30, 2009 | GE ZV950SDSS Kitchen Hood
Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Dec 24, 2008 | GE Monogram ZDP48L4GHSS Dual Fuel...
ZV800SJSS GE Monogram
most normal hoods cost about $60.00 to $100.00
Jun 10, 2008 | GE Monogram ZV1050SFSS 42" Island Chimney...
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
GE Monogram Wall Vent zv750SY blower Problems
javascript:launchURL('/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00035500/00035520.p01.pdf')
Jan 29, 2008 | GE ZV750SY Kitchen Hood
GE ZV750SY Kitchen Hood Logo
549 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
