Question about Health & Beauty
Pronto sure step
My chair will not start. what could it be?
4 Suggested Answers
  • 103 Answers
SOURCE: I have a inacare pronto m91 sure step. The SJ+
You have a remote, joystick, problem.
Posted on Nov 06, 2009
wcdoc1953
  • 278 Answers
SOURCE: i have oil leaking onto the left side tire of my
Sounds like you have a blown seal on your left gearbox. The only permanent solution is to replace the left brake/motor gearbox assembly. Not exactly a do-it-yourself repair. to verify, you can pull the seat off to inspect with a flashlight or tip the chair up at 45 degrees on the right drive wheel to inspect.
In my experience this is a common problem. It may take some time for enough gearbox grease to ooze out and cause the gearbox to fail. If you run the chair inside the house it will get messy very quickly and the grease stains are difficult to remove. If the chair is upwards of 4 or 5 years consider replacing left and right motor/gearbox assemblies. Hope this helps.
Posted on Dec 17, 2010
  • 68 Answers
SOURCE: one red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
Posted on May 01, 2011
Have a Invacare Pronto m51 Sure step. Trying to change batteries and the seat seems to be stuck
Turn chair on its side. get spray pb blaster on it. set chair upright and wiggle seat back and forth to loosen. It takes work but after it is apart use grease on mating parts so they do not stick together anymore.
Aug 01, 2016 | Invacare Health & Beauty
How do I reprogram my invacare pronto m51power chair
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
May 02, 2015 | Invacare Pronto M51 Power Wheelchair
I get error code 9, what do I do to fix this
Error Code 9 is a "Communications Error". The controller, or "Little black box" down inside the chair is not talking to the joystick, etc. First, check all the connections. Unplug, examine and clean all of the connections going into the controller, and the joystick connection too. Inspect all of the cables for damage to the wiring. If all looks good, then you likely have a bad controller....ouch. These are very expensive to replace new. You might be able to find a used one on Ebay, etc., or you could be better off looking on sites like Craigslist for a complete powerchair replacement. I have found near-new chairs for under a thousand dollars. Search for Pride Jazzy chairs too...a lot more of those for sale than Invacare chairs. Good luck.
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
What does a yellow wrench indicator light mean on a Pronto M41 w/Sure Step?
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
May 07, 2014 | Electric Mobility Pronto M41 Power Chair...
I bought a used m51 pronto sure step powerchair. The powerchair has no batteries or charger. I would like to buy a used charger and get batteries. Also where do you plug in the charger there seems to be a...
make sure it really doesn't have a charger ...
How,by taking that seat off,disconnect the joystick cable ,
take off the seat ,remove the black should which does or will cover the U1 Gellcell battery's you will have to buy. In the back of that chair there will be a box that has two cords one that pugs to the power cord( you'll also be needing to buy ,you can from radio shack if you don't have one that is)but the other wire connects to the model "'brain'' of the chair that's in the front of the chair. If its not there you'll need a on board charger,pluse two battery's and that power cable that plugs into the back of your chair ,It looks like and is the same as the power cable in the back of you computer.
Good luck hope I was of some help.
Jan 18, 2011 | Invacare Pronto M51 Power Wheelchair
I have oil leaking onto the left side tire of my pronto m71 sure step invacare chair. why? thanks for your help.
Dec 13, 2010 | Invacare Pronto M51 Power Wheelchair
One red light three green flash when turned on
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
19 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
