Canon dr 9080c
When scanning with the 9080c, the brightness seems to be way off no matter what brightness setting I use. It also seems to have a white streak on one side of the page. The bottom camera(on duplex) works great. thanks
Clean the Upper Reading Unit Glass with a soft cloth and isopropyl alcohol.
You may need to clean the shading plates by opening the top cover all the way and holding down the green start key until the shading plates extend.
Clean these with a soft cloth and isopropyl alcohol also.
Do not bend or tear these.
The clear stop key will retract the chading plates.
Posted on May 01, 2013
  • 32 Answers
SOURCE: Canon DR-9080c Ghosting Problem
Though I've never seen this on any scanner, I can imagine it being a reading glass out of place. This could cause a weaker reflected image overlaying the direct one. Look at the top & bottom glass strips in the transport area. They should look level & unbroken.
Posted on Apr 08, 2009
mohanchennai
  • 490 Answers
SOURCE: Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Posted on Jul 10, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
mohanchennai
  • 490 Answers
SOURCE: Getting vertical lines on scanned pages when
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
mohanchennai
  • 490 Answers
SOURCE: I am scanning few document on canon DR 9080c and i observer there
This must be a vertical line and appearing at the same location on all drawings! Please clean the glass thoroughly. It must be dust particle sitting on the glass.
S. Mohan. Chennao, India
Posted on Jul 21, 2009
Black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
Mar 29, 2012 | Canon DR-9080C Path-Through Scanner
Lower reading unit broken?
Ensure you have selected Duplex option. Canon DR 9080C uses LED lights and hence the chances of failure of light source is fairly low. Try scanning in Color.
The scan module, if required, can be replaced and is available in the market between $600 to $750. Please ensure that the module is faulty before replacing. (the upper and lower modules are interchangeable, except for a few plastic parts)S. Mohan, Chennai, India
Feb 24, 2012 | Canon DR-9080C Path-Through Scanner
Hi! this is my problem: my scaned copies from canon dr-9080c are darks... i cleaned every thing, but it sill being dark...
Select Automatic brightness instead of manual. Alternatively you can select 'manual' and reduce the brightness till you you are comfortable with the quality of output.
S. Mohan, India
Jun 25, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Scanner Canon DR-9080C recently started scanning at a slower speed. All setting look to be the same compared to another unit. Any thoughts?
Do you have enough disk space? Try disk Defrag and create more space. Also check the Format you are saving, is it TIFF compressed or uncompressed? The uncompressed file size is really huge.
Oct 02, 2010 | Canon DR-9080C Path-Through Scanner
We recently acquired a Canon DR 9080C Scanner and purchases and installed a SCSI card in an older HP Pavillion. The scanner works fine using the USB port, but when using the SCSI port I get an error when...
CapturePerfect ver 3 is on chargeable basis! You can download ver 2.0 from http://software.canon-europe.com/software/0022439.asp?model= Though this is listed under Canon DR 5020, it works fine with DR 9080C. DR 9080C has very intelligent features and ver 2 works fine. I do not know if there are addl features with ver 3.0. I have used for scanning over 500,000 docs.
S. Mohan
Aug 05, 2009 | Canon DR-9080C Path-Through Scanner
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
Need CapturePerfect 3 driver for Canon Scanner DR 9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
Jun 28, 2008 | Canon DR-9080C Path-Through Scanner
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
99 people viewed this question
jasbo
jasbo
