Maybe you dont have internet connection..you are only connected on local network...check your router setting or reboot your modem and router
check the network connection in control panel
right click on NIC card that you wanted to connect
click properties
select TCP/IP>>>click properties...select obtain IP automaticaly
then press OK...then close all windows
click start>>>run
type ...CMD>>>press enter
in DOS prompt...type ipconfig /release...then press enter
then type ipconfig /renew..press enter
The internet is connected, i can use it on my ibm t61 but unable to connect on the other laptop
Thank you for your help it worked
