Question about Kodak EasyShare C875 Digital Camera
I own a canon power shot A 550 camera.
My little daughter dropped the camera in a switched on mode with the lens in the zoomed position, since then the lens does not retract back to the neutral position and the displey shows the following error message on switching on " Lens error, restart camera".
kindly help, is there a proper kodak digital camera service center in Lucknow( india).
thanks..
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
I've dropped my Canon Power Shot SD960 IS with the lens out, and now the outer lens is tilted at an angle and wedged tight and the barrel of the zoom will not retract. I've tried turning it off and on,...
Try this first, power off and gently push the lens barrel sideways - not back in!, If the barrel and the lens move slightly, you will get it working after some more manipulation in the same way. If it does not budge, sorry to mention this but your camera sustained more damage and you cannot do do much on your own.
Aug 14, 2013 | Canon PowerShot SD960 IS Digital Camera
I HAVE A CANON POWER SHOT A520. THE ZOOM LENS WAS OPENED AND I DROPPED THE CAMERIA AND THE LENS WHEN INTO THE CAMERIA. NOW THE ZOOM DOES NOT OPEN ANY MORE. THE LENSE IS OPEN AND DOES NOT CLOSE. I GET NO...
I know this is not the answer you want, but when you dropped the camera you damaged the lens tube (housing) and your camera will require professional repair.
Sep 13, 2009 | Cameras
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Nov 08, 2007 | Canon PowerShot A620 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
42 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
