What yr. was model number LPR6244AWO washer manufactured?
I am getting an F30 flashing on my washer. Why
Please check the full model number of the washer. Kenmore appliances are built by other manufacturers and the fault code will depend on that manufacturer.
However, the F30 code is most likely for a Kenmore washer built by Whirlpool. If this is the case, the code means a problem with the detergent dispenser. The dispenser is controlled by lever that needs to move between two points as the gears go through the cycle. Sometimes the lever gets bent out of position or the control wires (or other items) get into the gears and blocks the motion. Sometimes, you can hear a clicking sound as the dispenser tries to engage. If you take off the top of the washer and then run a wash cycle, you can observe this action. Check what may be blocking the dispenser and adjust things so that everything moves freely. If that fails to solve the problem, replace the dispenser.
If the washer is under warranty, contact Kenmore. Most Kenmore appliance parts are available from Sears Parts Direct . However, you will need the full model number. (The model number has a 3 digit prefix that indicates the manufacturer. The last 8 digits are the product model. There will be a period after the first three digits. Most front load washers will have the model number inside the door on the frame.)
If you post a comment with the complete model number, I'll be glad to offer additional help and the exact parts diagram for your washer.
Aug 24, 2012 | Kenmore Elite 45986 Front Load Washer
We moved into a new house that has a Whirlpool Duvet washer and dryer. I was wondering what year they are. Model # for the washer is WFW9300VU02 and the serial number is CSW4003338
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how to determine the age of your Whirlpool appliance:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The SECOND DIGIT in the serial number represents the YEAR the appliance was manufactured. The first two numbers following that digit, represent the WEEK (52 weeks in a year) the appliance was manufactured. So, based on the serial number you have listed, the WASHER was manufactured in October of 2005.
These appliances are commonly sold as a set, so you may find the dryer was manufactured around the same time. If you need assistance determing the age of the dryer, please post back with the SERIAL NUMBER and let me know. I hope this helps you.
May 04, 2011 | Whirlpool Washing Machines
Help...my one yr. old pushed buttons and brought up the menu...my four yr. old thought the way to get that off the screen was to turn the tv off and back on. well, he turned it off, but it won't come back...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 29, 2010 | JVC AV-36320 36" TV
I'm trying to find out how old my mothers wash machine is. The model numbers in 2270
The date of manufacture is determined by the SERIAL NUMBER on the appliance. Since Kenmore washers are manufactured by Whirlpool, the following link explains how to determine how old your washer is:
The serial number will be listed on a nameplate along with the model number along the wash tub rim under the lid. The second DIGIT in the serial number identifies the YEAR it was manufactured. The first set of NUMBERS following that digit represent the WEEK it was manufactured (52 weeks in a year).
If you need help determining the date, please post back with your serial number so I can assist you. I hope you find this information helpful.
Mar 29, 2010 | Kenmore Washing Machines
Kenmore Washer Model 110 Serial Number #CF2915758 when was it manufactured
The following link explains how to determine the date of manufacture for a Kenmore:
Thank you for providing your serial number. According to the information I provided, your washer was manufactured in July of 1996. Kenmore is manufactured by Whirlpool so this advice does apply. If you have any questions, please let me know. I hope this helps you.
Mar 24, 2010 | Kenmore Elite 45986 Front Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
How to disasemble model 11020722
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem.
Can you describe exactly what you want to disasemble??
Jan 25, 2010 | Kenmore Washing Machines
What year was the 110.28812790 washer made?
The dates of manufacture are determined by the SERIAL numbers on the appliance. The following links explain:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Your Kenmore is manufactured by Whirlpool. The first two numbers in the serial number identify the WEEK it was manufactured. The digit preceeding the first set of numbers, identfy the YEAR.
http://www.fixya.com/support/r2880528-determining_age_maytag_appliance
On Maytag models, the last two letters in the serial number determine the date of manufacture. The first letter is the YEAR, the second letter is the MONTH.
Nov 11, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer age
Your washer was manufactured in March of 1993. The manufacture date is determined by the Serial Number. The second letter "C" represents the YEAR of manufacture. The first two numbers "14" represent the WEEK it was manufactured. The 14th week puts the manufacturing in late March. I hope this helps you.
Sep 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer GLTF2070DS0
warranty varies by manufacturer some stainless steel baskets had 10 yr warranty but suspect you may need more than just basket outer shell has a bearing in rear that is pressed in only repair is replace rear shell and basket.. 2 men 2 hrs plus outer shell price and labor.. only 1 yr labor and other parts
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
