Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
No start it doesn't power up, battery acid build-up on door, idaes?
Regrettably, if it the camera won't power on and is showing acid corrosion on the battery door, then the camera is well and truly dead. The battery door won't have been the only thing corroded by the battery acid -- it has more than likely migrated to the internal circuitry and damaged it irreparably.
Posted on May 29, 2009
My car dont start all the time
I would check your battery cables and make sure they are tightened secure to the terminals and there isnt any acid corrosion build up on the battery terminals. If there is build up poor a coke on them and close the hood.
Aug 18, 2012 | 1999 Oldsmobile Alero
When i open the hood on my 1999 jetta it smells of acid and their is white powdered acid all around the positive pole
I would replace the battery, but if you are unable to I would go to a parts store and pick up some terminal cleaner. That would take care of the acid build up giving you a better connection.
Apr 27, 2012 | 1999 Volkswagen Golf
Zuma kick starts but wont elec start. any ideas.scooter fell and now no start, do here click though
BAD BATTERY CONNENCTIONS OR BAD BATTERY..PROBABLY CRODDED BATTERY CABLES..BATTERY MAINTAINCE SHOULD BE AT LEAST EVERY THREE MONTHS..AT LEAST A GOOD LOOK ONCE A MONTH..CLEAN,, CLEAN, THAN COVER IN VASOLINE TO PREVENT CROISSION BUILD UP..THE POSTIVE AND NEGITIVE LEADS..AND ON ALL CLEANED CONNECTIONS..BAKEING SODA AND COKEACOLA ARE GOOD FOR ACID CLEAN UP..WEAR RUBBER GLOVES AND EYE PROTECTION..BACKING SODA DEACTIVATES THE ACID.AND IS SAFER THAN NOT USEING..AFTER, RINSE VERY WELL WITH LOTS OF WATER..THE BEST IS TO REMOVE AND WORK IN A CONTROLLED INVIREMENT..
Jul 25, 2011 | Yamaha XT 225 Motorcycles
Car won't start. There's no clicking sound but auto seat belts and some dash lights come on dimly.
Check the battery charge and also check that the battery terminals and clamps are clean and free of corrosion and acid residue build-up. If there are signs of acid or build-up, clean with boiling water only. Do not use baking soda or bicarb!
Jan 19, 2011 | 1993 Mercury Tracer
My car want start battery is fully charged. But the immobilizer light on the instrument panel stays on?
Having a full charged battery won't just solve the promblem. You might want to check with the battery terminal connection on the postive+ and negative-, It might be corroded, grease, or acid build up, so check for thse signs, also it could be that clamps are not fully tighten. You still can get power to the car from the baterry which in this case is leads to the immoblizer lights on the dash boards to stay on, but the terminal are corroded with acid, grease, or just from dirt, and with these element in presence, the battery is not fully ground. The engine needs a specific amount of amplitude from the battery for the engine to crank. A kia sorento v6 engine needs alot of cranking amp. So my solution is, check the battery connection terminal on the battery and the cable (positive and negative connections) de-tach the cable connections, clean the connection cables which are the adapter to the battery, and the battery terminals, with a toothbrush or high grit sandpaper until dirt, acid build up, grease are gone, and reinstall the cables. See if this will help.
Jan 03, 2011 | 2003 Kia Sorento
2000 Saturn sl2 will not start.
Check positive cable at battery for corrossion between cable and battery,probably leaking acid at post.
Jun 09, 2009 | 2000 Saturn SL
2006 Chevrolet Equinox LS 3.4L battery exploded
First, I hope you diluted the battery acid with a little water. Most batteries create explosvie gas (hydrogen). If it isn't vented well, the gas could build up and a spark from even a dirty terminal can set off the gas. Are you saying that you've determined that Chevy Equinox cars are prone to explode their batteries? A sealed battery, such as the Optima, releases no vapors. Such a battery would probably solve your problem.
May 26, 2009 | Chevrolet Equinox Cars & Trucks
APC UPS issues
If its really a noise? neutral and ground of your utility power (building transformer) should be bonded
Apr 14, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Will not start
Disconnect the black battery cable, then the red one. Clean both the cable terminations and the battery terminals with a wire brush to remove all corrosion. You can also buy a spray to neutralize any acid residue. When the connections are clean, reconnect the battery - red first, then black. Tighten firmly, but be careful not to strip the threads. Finish by sealing with a protectant spray. Note this is a different spray, not the cleaner mentioned earlier.
Oct 12, 2008 | 2002 Kia Optima
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
124 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
