Question about Samsung Televison & Video
How to fix my samsung tv
My samsung tv is stuck in mode not supported model number LN-R328W
  • Samsung Master
  • 5,380 Answers
What's the source of the signal for the LN-R328W. The mode not supported message shows up when the source signal is not compatible with the TV. For example: if the source is a computer, use a different monitor to make sure that the refresh rate is 60Hz. Next, turn on the TV and set it to the VGA source before you turn on the computer. (Most modern computers will then see the TV as a monitor and set the correct resolution.) Note: this TV can't support an HDMI signal from a computer. (The signal is different than that for a Blu-ray player or HD set-top box.)
For game stations, you may need to check the manual for the box to set the resolution for your TV.
I hope this helps.
Posted on Apr 25, 2013
SOURCE: Samsung LN-T4042h to PS3 "Not Supported Mode"
i fixed it, on the PS3 u hold the power Button while holding then Switch the power button on on the back for like 10 sec and it resets the picture settings to default
Posted on Nov 21, 2009
SOURCE: Samsung LN-R328W TV Psychedelic picture
Multiple color lines around the image is most likely the convergence is off. from the menu find the option for convergence
follow the adjustment prompts. if that don't work the board has two IC's that are probably bad
Posted on May 09, 2008
techman
  • 3130 Answers
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
headstrong
  • 233 Answers
SOURCE: not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Posted on Dec 29, 2007
rlamkin
  • 44 Answers
SOURCE: Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Posted on Jul 03, 2008
My 40" Samsung lcd went to no pic. but the sound works. Help...
Hi there
It sounds like your inverter board went bad. check out on the part number and look for it on ebay you will safe some bucks
Oct 18, 2013 | Samsung LN-R328W 32 in. HD-Ready LCD...
I CANT LOGIN TO SERVICE MODE TO MY TV SAMSUNG LN-R328E PLEASE HELP ME
Unplug,replug tv back in about an hour later.Every setting,should reset now.All functions,should work now.Not,than the Tuner board,that the board have the incomming broscasting signal cable plug into it,have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Jul 30, 2010 | Samsung LN-R328W 32 in. HD-Ready LCD...
Color problem
hi it could be a loose cable in the back of the tv
Jan 10, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LNR328w, T-Con Board
What is the part number on the board?
Dec 30, 2017 | Samsung LN-R328W 32 in. HD-Ready LCD...
Jul 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Not supported mode lcd tv samsung lnt4061f
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
660 people viewed this question
Jerry Greenberg
Jerry Greenberg
