Samsung ln r328w
The screen says mode not supported
  • 575 Answers
Green spots on screen of Lcd
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD are given. You can compare it to that of your TVs' and can make sure about the fault.
Apr 19, 2014 | Samsung LN-R328W 32 in. HD-Ready LCD...
How to fix my samsung tv
What's the source of the signal for the LN-R328W. The mode not supported message shows up when the source signal is not compatible with the TV. For example: if the source is a computer, use a different monitor to make sure that the refresh rate is 60Hz. Next, turn on the TV and set it to the VGA source before you turn on the computer. (Most modern computers will then see the TV as a monitor and set the correct resolution.) Note: this TV can't support an HDMI signal from a computer. (The signal is different than that for a Blu-ray player or HD set-top box.)
For game stations, you may need to check the manual for the box to set the resolution for your TV.
I hope this helps.
Apr 25, 2013 | Samsung Televison & Video
Half the screen on tv is blue
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 17, 2012 | Samsung LN-R328W 32 in. HD-Ready LCD...
I CANT LOGIN TO SERVICE MODE TO MY TV SAMSUNG LN-R328E PLEASE HELP ME
Unplug,replug tv back in about an hour later.Every setting,should reset now.All functions,should work now.Not,than the Tuner board,that the board have the incomming broscasting signal cable plug into it,have problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish Tuner signal board for the replacement.
Jul 30, 2010 | Samsung LN-R328W 32 in. HD-Ready LCD...
Have lines going accross screen that look like blinking colored d
Bad or loose wire. does this happen only with tv or with dvd and video game too.. check too see if it is every unit then problem is either tv itself or wire connection
Apr 27, 2009 | Samsung LN-R328W 32 in. HD-Ready LCD...
Loose HDMI Connection
Dont use the HDMI connection OR replace the main board. Its directly soldered to the main board. The back should come off IF you have removed ALL the screws and the little screws things that hold on the VGA connections etc. There are also some obscure screws holdin the back on.
Jul 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Damaged plasma screen
the cost would be too much..better to replace the set and be more careful.
Sep 14, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Aug 06, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
