Question about Baby Gear
Front clip on strap broken, where can I find a new clip?
    Scholar:
  • 124 Answers
Without knowing the brand or model of your car seat, I'd recommend checking the company's website and contacting their customer service about replacement parts. They should be able to help you with this.
Posted on May 07, 2013
Shoulder strap clip has broken
You have to unpick and sew a new on in. Its a 25 mm black plastic swivel clip most sewing shops or haberdasiers will have or can order one,
Sep 23, 2013 | Bugaboo Cameleon Stroller
Strap Connector Clip (UK User)
most binoculars can be bought from camera shops along with telescopes. Try the one closest to you and if they haven't got what you want may be the next best thing is to buy a new strap.
Jun 22, 2013 | Bushnell Excursion EX 8x42 mm Binoculars
How to use an eurowrapper bundling gun
Very carefully. What kind of computer does the gun work on?
Jan 08, 2013 | Computers & Internet
How to change fuel filter on 1997 Ford 150
Things You'll Need
  • Drop pan
  • Socket set
  • Fuel line disconnect tool
  • New filter
  • 1Slide the drip pan under the driver side of the truck, below the driver door. Climb under with the socket set, fuel line disconnect tool and new filter.
  • 2Unbolt the fuel filter retaining strap with the socket set. The filter is located along the inboard side of the frame, below the driver seat. When in doubt, simply follow the fuel lines forward from the fuel tank until you locate the filter.
  • 3Disconnect the front fuel line from the fuel filter with the fuel line disconnect tool. The line flares out where the filter outlet enters it and a retaining clip holds it in place. You can unseat this clip with a pocket screwdriver or a pick, but it's not advisable, as the clip tends to break if pried on unevenly. hence why u need the tool. about ten buck
  • 4Pull the fuel line off the front of the fuel filter and then pull the filter out of the rear line and retaining strap. Put the old filter in the drip pan.
  • 5Slide the new filter into the retaining strap and plug the inlet into the rear fuel line. Make sure the arrow indicating flow direction points toward the engine. Connect the front fuel line, push the retaining clip back into place and bolt the retaining strap back to the frame.
  • 6Climb out, get in the truck and turn the ignition key to the run position. Wait for the fuel pump to stop running (this should be about 10 seconds) and start the truck.
Nov 18, 2011 | 1997 Ford F150 Regular Cab
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Sep 08, 2010 | Evenflo Generations
GE Profile washing machine leaks from the bottom . How to we get to the hoses and pumps?
There could be a screw on each bottom coner of the front panel. If not, take a putty knife (1 1/2" or 2"wide) Slide it between the lid and the front panel. You should fill a clip about 4" or 5" from corner. Pull putty knife out and then use it to push into each clip while pulling slightly on the front panel. Front will come off a corner at a time. From here you will be able to access everything.
You are most likely going to find that the plastic outer tub is cracked and all four round rubber straps located at the top of the tub broken. If so, you will be better off to replace machine because of the cost of a new outer tub and the labor required to replace it. If you chose to replace tub, you will need a tub wrench. The last one I bought was $68.00 15 years ago.
Please rate this solution
Aug 27, 2009 | GE Profile Performance WPSF4170WAA
Broken harness on bugaboo cameleon!
I actually called bugaboo and they are sending me a new clip. covered under my guarantee.
Jun 12, 2008 | Bugaboo Cameleon Jogger
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Aug 02, 2007 | Evenflo Embrace
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
