Question about Dell Dimension 4700 PC Desktop
Moniters menu comes up without pressing the menu button
The moniters menu comes up without pressing the menu button,
it goes away when you press the exit button
    Problem Solver:
  • 10 Answers
You will need to 1. try to unstick the button on the front of the monitor or purchase a new monitor I had a Compaq 17" monitor do that to me and the button was stuck sideways Let me know if I can help out anymore
Posted on Mar 18, 2009
My brightness monitor appears in the lower right quarter of the screen and does not go away. When I press and hold the right button, it disappears, but as soon as I release, it comes back. The screen is...
Hi
It's likely you have a sticky button.
Look carefully to see if you have a Menu button, enter the control panel and use the arrow buttons to scroll to the exit icon and then press menu again to manually exit.
I hope this helps.
Aug 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
My lglf7700 has the passcode enabled and i have forgotten it how do i do a factory reset please.
Try this...
The following functions are going to vary depending on the LG model that you have, as manufacturer updates are made without consumer notice.
Turn on the TV, press and hold the menu button on the remote and on the TV simultaneously until a menu shows on the screen. That *MAY* be the service menu.
On the bottom of that menu there will be a selection that reads "load defaults." Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button on the remote.
Or try this...
Turn on the TV. Press and hold the menu button on the remote until a 4 digit passcode prompt comes on the screen...should take about 5 seconds. Enter 8741. Another menu *MAY* come on the screen with a selection for loading factory defaults. Toggle down to it with the remote, press enter and then exit the menu by pressing the menu button again.
Jul 04, 2010 | Televison & Video
AOC LCD MONITER OSD LOCK
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
LARGE BLACK RECTANGLE BAR BLOCKING TV SHOWS -- WILL NOT GO AWAY
It sounds like the closed captioning background.
Press Menu on the remote
Press Up or Down, Ch + or C- to get to Closed Caption
Press right side button or Vol+ and Mode will be highlighted
Press right button or Vol+ until it says Off on the right hand side of the Menu
Press exit and that should do it.
Hope this helps.
Oct 17, 2008 | JVC AV-27D303 27" TV
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Dell Dimension 4700 PC Desktop Logo
48 people viewed this question
Alun Cox
