Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Brush turning vacuums in strips
  • Bissell Master
  • 18,392 Answers
  • britneyparkin Apr 26, 2013
    hi my name is britney
Does the FH50020rm Cleaner model use more than one brush
the FH50020 does not have the turning brushes under it. It only has a brush strip running across , behind the nozzle.
Jun 02, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My brush stop working
Barring any electrical failure or loose plug the most common cause for the vacuum brush to stop turning is belt clogged with debris or string.
Unplug the unit and check the brush for string or debris (Hair) wrapped around the pully on either end. Clear this and check the belt to make sure it has not broken, stripped or simply slipped off. Usually the bottom plate is held on with just a few screws. Easy to remove and check Belt slipped off or stripped replace. Belt slipped off you can sometimes put back on and be vacuuming in no time.
Anything wrapped around the spindle a pair of needle nose pliers comes in real handy here. If you have snagged a rug, sheet or sock etc.. check the manual for a reset button. Some vacuums have this and all it takes is clearing the chute then resetting the switch. Good luck hope this helps!
Apr 03, 2014 | Vacuums
Dyson brush bar stops when I move forward
Make sure that the brush does not have lots of hair etc jammed around it. If there is anything that will cause resistance to the brush bar turning, a sensor will immobilise the brush until it is clear. Be careful how far you strip it back to as there may be warranty issues if you do more than undo the bottom with a penny, so you can use scissors to cut away at the hair or carpet fibre entanglement. Good luck
Nov 24, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
Floor brush won't turn.
if yours is a dual motor unit a microswitch in the base of the vac powers the brush roller, additionally the carbon brushes may need replacement..far cheeper than a motor.
or your belt may be stripped or streched due to string or hair binding the bearing
Aug 03, 2013 | Clarke CombiVac 12 Bagged Upright Vacuum
Why won't my brushes turn
most likely stripped gears on the end of the brushes. (beltless model?)
Nov 21, 2011 | Hoover WindTunnel V2 U8148-900 Upright...
When I vacuum, I get 1" wide stripes where the
Inspect the brush.
Turn on the vacuum, CAREFULLY pivot the machine so the front goes up and the rear wheels stay on the ground. Is the brush rotating.
If not, inspect the belt after turning the vacuum off and unplugging.
It they are rotating, inspect the brush with the machine off and unplugged. Are there high & low spots?
Gary
Jul 11, 2011 | Bissell Upright Vacuum - The Pet Hair...
Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Irobot 415
gears may be stripped in the brush drive line. right off the motor is a gearbox, held on with two screws. getting to it is fairly complicated, fix is easy. parts can be found at Protech Robotics Parts and Service
Mar 22, 2008 | iRobot 4150 Roomba Vacuum
Roomba Discovery
The plastic gears that drive the sweep brushes strip out easily on these. You can get the company to repair it for you but they make it a big hassle. I opted to buy the gear set on EBAY and replace them myself.
Dec 04, 2007 | Roomba Robotic Floor Bagless Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
