Question about Toro Garden
328 d engine start but won t stay running
The motor starts and runs smoothly for a few minutes, weakness when engaging blades or going up small hills It is diesel, is it a shortage of fuel, is it the airfilter or a deeper issue any ideas
SOURCE: mower starts won't keep running
check the bowl under the primer button see if there is dirt in there watch how it comes apart,then send me email cant get mine back together,mine was dirty should help.
Posted on Sep 19, 2008
  • 119 Answers
SOURCE: toyota diesel engine very rough on start but then runs smooth
Check the heater plugs normaly when the engine is cold heater plugs work to heat up combustion chamber then starts easy,also long raning fuel filter mybe so change the fuel filter.
Posted on Nov 14, 2008
honeymokey
  • 3113 Answers
SOURCE: hard to start and won't stay running
Put fuel in it,then check the fuel pressure with a gauge. The tank unit maybe giving a false reading.
Posted on Apr 19, 2009
  • 137 Answers
SOURCE: WON`T START COLD, STARTS ON STARTING FLUID 96 TRACKER
96 , TRACKER?
IF IT RUNS AND STAYS running. then that means the car is flooding or is in a sad state of tune.
tune it up and it will start every time.
if not ask me here.
http://www.kick-fix.com/
see my guest book. ask a question.
1; tune up
2: bad ECT sensor.
3: stuck closed IAC.
my page answers all sidekick questions.
Posted on May 14, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
My zero turn RZ4623 will start & run fine in idle, but with blades engaged it only runs about 20 to 30 minutes, and quits.
check your battery if it is weak sometimes the PTO takes all the voltage and motor can not run.
Aug 02, 2016 | Husqvarna Garden
Why is it hard to start?
run the fault codes and check for problem MAF/VAF sensors or throttle position motor fault
Nov 16, 2015 | Cars & Trucks
Automatic choke problems
Yes, spring may have broken or maybe it just needs adjustment. There is a high idle cam that makes the card idle higher when the choke is closed or partly closed.
Dec 20, 2017 | 1982 Porsche 911
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
Want to know the carburettor L and H screw adjustment of Makita Power cutter DPC 8132
On both screws, turn them in just until they seat, not tight. Back them out one full turn. Start the motor and let it run until it gets up to temperature. If it won't start or stay running, turn the L screw out another 1/2 turn. With the motor idling, turn the L screw in just until you hear the motor tone change then back it out until it smoothes out and keep going until the motor tone changes or starte running rough. Turn it back in half way between these two points. With a blade on the saw, hold the throttle at about 1/2 to 3/4 full and adjust the H screw using the same method.
Feb 16, 2012 | Saws
Started craftsman lawn tractor 24 hp kohler engine drove it a few feet engaged blade clutch and mower stopped. disengaged blade clutch tried to restart . engine turns over starts runs few a few seconds and...
You should be able to push it forwards as well as backwards. I had a similar problem (engine stalling) with mine. I found out if I half choke it, it will stay running. Transmission may still have a problem.
Jul 29, 2017 | Craftsman 24 Hp 48" Deck Yard Tractor
The 12.5 murray 38 in runs fine until i engage the blades,while engaged the mower runs fine for about five seconds then starts to spit and sputter.once i disengage the blades it runs smoothly again
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Jul 07, 2011 | Garden
I have a craftsman mower with the B&S 21hp Intek OHV motor, it starts fine but when you go to engage the blade or go forward or backward or release the parking brake it will die unless you disengage...
Check the switch on the seat, of all places. There's a safety switch on the seat that will kill the engine if it's not engaged when do anything other than start and run the engine.
If the switch checks out, get back with me.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor backfires
It sounds like your engine is firing out of time.
Here is a link to the manual for your engine. It does contain some good info and I hope it will help you to solve this problem.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Best of luck!
Aug 31, 2009 | Garden
Garden Logo
23 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
