Question about Health & Beauty
Childs Nebulizer Tube connected properly and air flow is good but it's not creating any steam.
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 11 Answers
Trying to help ya
Posted on Apr 30, 2013
5 Suggested Answers
l@dy ace
SOURCE: nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Posted on Dec 08, 2008
  • 31 Answers
SOURCE: no medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
Posted on Jun 26, 2010
  • 31 Answers
SOURCE: my nebulizer isn't producing steam what is wrong?
Most likely the disposable neb kit is bad or put together incorrectly.
Posted on Jun 27, 2010
dhmankad
SOURCE: I HAVE A SUNRISE NEBULIZER MODEL#46502. THE AIR
send to baroda dhmankad@yahoo.co.in mo 09426066704
Posted on Oct 17, 2011
Where is filter to clean on neb. Air flow present. But, tubing popping off and not enough airflow to produce proper steam and med inhalr. Did check tubing and chamber. Both new. Any suggestions?
May be defective nebulizer, or may need diffuser reinstalled. Inside bottom of neb cup (unscrew top half) is small plastic piece (diffuser) that mounts directly over the hose connector (on outside) U can pull the plastic piece up to make sure its not too tight ,can come out-just push back on- or push down if too loose (poor air flow stream) If the diffuser is lost or broken you need a new nebulizer. If home care company wants to charge you more, tell them they gave you a defective nebulizer. Im a retired RRT
Feb 08, 2018 | Medical
Where do you load the inhalation solution?
You may have already figured this out by this time, but figured that others could have the same question. Here's a simplified explanation on how to assemble and use the nebulizer. I apologize if the explanation sounds patronizing. I'm not sure of what you may or may not understand about the nebulizer, so I'm explaining as though you don't understand it. I'd rather someone explain something in a patronizing way, than assume I have knowledge that I actually don't. At least with the former, it's easier for me to ensure my questions are answered. I also apologize for my ADHD. It often cause me to write much more than is necessary or overexplain things.
There should be two pieces that screw together to make the reservoir.
Piece #1 is the male side/bottom side and may or may not have a green cone inside. If not, there are still a plastic piece inside that forms a cone shape. This side should also have a small plastic cylinder shape on the bottom. This is where one side of the supply tube should be attached.
Piece #2 is the female side and has a larger cylinder shape on the top. When the piece is turned on its side, it sort of resembles a flashlight. This is what the breathing apparatus is attached to. You attach the tee adapter to the tube side of it. Then you attach the mouthpiece to whichever of the tee sides it fits best. Once this is all assembled, attach the other end of the supply tube to the nebulizer.
Now, back to your question. Open the reservoir, pour the solution into Piece #1, then screw Piece #2 back on. It should only take a second or two for the steam to begin flowing through the breathing apparatus once you turn the nebulizer on. Also make sure the the supply tube is attached securely to both the nebulizer and the reservoir so it doesn't pop off. Now you're ready to begin.
If you start coughing during treatment, that's fine. Don't remove it from your mouth or stop treatment. My mom was my son's pediatric nurse and trained us on its use. She said that if you start coughing during treatment, that actually helps you to inhale even more of the solution which is beneficial..
Aug 02, 2013 | Salter Labs 8900 Series Small Volume Jet...
Nebulizer won't put out steam
Make sure compressor is putting out air.
Then make sure funnel looking piece is in the nebulizer cup.
John
Lighthouse Medical
Mar 13, 2013 | Ultra Products Ultra Sonic Compact...
My nebulizer is not making fumes
Try this. Begin by disconnecting each end of the tube from the bottom of the nebulizer running water through it. This will help dislodge andy blockages.
Turn the top of the cup and lift it off. This will expose the cup baffle. Take the baffle and the cone out of the cup. Rinse it with warm water and dish soap to remove clogged medicne.
Wash out the cup by soaking it in warm, soapy water. Rince out the cup until all of the soap is gone, and make sure water is flowing through the cup openings.
Reattach the hose to the output port on the nebulizer and make sure you have a good connection. Put the loose end of the hose onto the bottom of the cup and reassemble. Make sure you put your medicine in before you reassemble the cover.
If this doesn't work, make sure you have power running to the device. Check all of your connects and try a different outlet.
Mar 01, 2011 | Computers & Internet
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
PulmoMate nebulizer will not create mist
Make sure your unit is clean and you have a clean filter. Tighten all of the connections. make sure your medication is mixed properly as well.
Apr 20, 2010 | DeVilbiss PulmoMate Aerosol...
Omron nebulizer will not mist. All tubing is intact. What to do?
You'll read a lot about making sure that the filter is clean and that the medicine cup is cleaned and that hard water can effect the operation of the nebulizer. However, the problem is most likely in the pump. Even though the pump is running, it is not pushing enough air into the medicine cup. You may even feel air coming out of the tube. When unrestricted, the air will come out, but, once restricted by the medicine cup, the air may not be fast enough to nebulize the liquid. If you want to confirm this, take the tube and hold it to the end of a bike pump, if, while pumpung, you successfully see mist, then you know for sure.
Fixing the pump is not too difficult. Over time, the chamber where the air is compressed becomes dry and, just like a dry bike pump, the air escapes from the chamber due to poor seals. The pump is pretty simple. Make sure it is unplugged from power and remove the screws holding the housing together. Inside you will see the motor, a fan, a power switch and the intake and outtake tubes. Follow the outtake tube to the pump. The junction where the tubes meet the pump is the location of the air chamber. You may need to remove the screws that secure the tubes to the chamber. Once apart, take some grease and lightly coat all of the interior surfaces of the chamber. When finished, reassemble and you're good to go!
Mar 23, 2009 | Omron Healthcare Omron NE-C25 COMP-Air...
Nebulizer portion is accumulating what appears to be saliva
Dec 01, 2008 | RTO Spider Nebulizer
Health & Beauty Logo
201 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
