Question about Kohler Forte entertainment remote valve sink faucet with Sidespray ...
Kitchen faucet my kohler kitchen faucet K10441-CP spout will rise up ( I mean pop up compleately) from base when water pressure is high. It's like the spout is not attached with the base. I don't know how to describe this problem better. Never seen this problem before. there is no leak. Thanks1 Pepper
  • marty metzger May 11, 2010
    spout pops off and there is no leak?
  • 68 Answers
Look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Posted on Mar 15, 2009
The kitchen sink faucet is clogged
If it just the hot or just the cold then it will be the shutoff valve not the faucet. replace the valve/s under the sink Try checking the screen in the head of the faucet for sand. If it does not have a screen(some dont) then it will have a restrictor usually green in color that may have debris inside of it.
Jan 06, 2013 | Kohler K-692-VS Clairette kitchen sink...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
Why would spout leak at the swivel?
The swivel base needs to be tightened. There is a gasket underneath.
Jan 09, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Kohler Forte entertainment remote valve sink faucet with Sidespray ... Logo
260 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
