Question about Nokia N97 Cell Phone
My n97 is not charging,
If i plug my charger it will show charging ad after some seconds it will say not charging
    Problem Solver:
  • 8 Answers
Replace charger
Posted on Apr 25, 2013
Samsung 3262 charging paused for battery
Since you are experiencing difficulty in your charger since your Samsung 3262 won't charge although it is showing it is charging battery then we will be solving this matter so to fix battery and charger problem. • Performing a power reset. •Hold the power button for 30 seconds without it being plugged in. •Then place your Tab on a home charger for a couple minutes. •After a couple minutes, press the power button again for 30 seconds with the charger plugged in. This is usually a charger issue But in a small amount of cases it can be the battery. If recently purchased you can just return it and get a new phone.
Sep 29, 2014 | Cell Phones
My nokia n97 is not charging its show not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 14, 2012 | Nokia N97 Cell Phone
I have n97 but there is problem that when i connect the charger the led is on & battery bar showed no response nor charged with usb cable or usb charger .what should i do because in my city no one can...
It looks like the battery in the phone is not accepting the charge. This can be happening if the battery has gone bad. Please contact Nokia people for further assistance.
Please feel free to contact us for further information.
Jan 05, 2011 | Cell Phones
My n97 is not charging with the charger, only the usb cable. how do i fix this? is it my battery or phone or charger?
It sounds like the charger is the problem. The battery and the phone seem to be ok since you can use the usb cable to charge the phone. I would check the charger to see if there is any visible damage. You can also see if a friend has the same connector (many new phones should due to the EU ruling last year) and check their charger with your phone and their phone with your charger to verify the charger is faulty, but replacing the charger would probably the best solution. Depending on how long you have had the phone, Nokia might cover the charger under the warranty, but I don't seem to be able to find that information.
Nov 30, 2010 | Nokia N97 Cell Phone
Hi i bought a nokia n97 almost a month ago,and one time i went to bed and left it to charge and woke up with the charger not working. ive been told its an electrical problem so i changed the charger,now...
In the manual with my Nokia 5230 Nokia says that when the indicator gives a sign about the unit being fully charged one is supposed first to take charger connected to the phone first and then the plug from the electricity. Take another look at the manual of your phone and checkonthe information on charging
Jun 13, 2010 | Nokia N97 Cell Phone
Phone is in the charger and after charging for a little bit it stops charging and says "warning bad contact of charger" how do I fix this problem for nokia n97. Please help
Hi, the problem is with either the phone charger or the charging port IC.. First of all, change your charger and see if the problem will still repeat itself, if it does, then you have to take the phone to a phone technician to change the charging IC.....
Feb 25, 2010 | Nokia N97 Cell Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Nokia N97  Cell Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
