Amana tandem 7300 washer
I would like to get a manual on my washer and dryer
caroldon
  • 17129 Answers
SOURCE: I have a Amana tandem 7300 it starts beeping and stops working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Dec 11, 2012
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
ginko
  • 19396 Answers
SOURCE: water will not drain from
Hi.
You need to access drain pump and check drain hose at the back. There are also a couple of parts to be tested. For those you may want to call a technician.
The access to the drain filter should be located at the front bottom side of the appliance, behind a protective trim. In there you should find a cap that can be unscrewed to release water and remove blockage. Have a container ready to collect water. If there is no access in front, then access is at the back (uncommon).
If there is no blockage at pump, check the hose at the back.
Ensure that the height of the hose elbow is respecting the specifications indicated in manual. Check that the top of drain hose is not lower than 30" (760 mm) . A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
To start and complete drain part of the cycle, the electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle.The pressure switch is a round shaped parts connected to a long rubber hose that goes inside the tub. The switch and hose must be cleaned or replaced. Pressure switch is located in the control assembly.
Access the control panel and clean the hose attached to the pressure switch.
Also check the lid is closing well.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Here the user manual:
Amana NFW7300WW Washer Laveuse Automatique a Chargement Frontal Guide d' Utilisation et d' Entretien - Front-Loading Automatic Washer User & Care Guide.pdf
Regards.
Ginko.
Posted on May 01, 2011
  • 5103 Answers
SOURCE: I need, Owners manual for
Most Amana manuals are available from their Customer Service site: http://www.amana.com/content.jsp?pageName=CustServ . Enter the model number in the Manual and Literature search box and click the > button.
Which version of the NFW7300WW and NED7300WW do you have? The Amana site gives 3 different models which add 00, 01 or 02 to the end of the model number for the washer. The file lengths vary from the 00 to the 02 versions. There are two versions of the dryer; the model number gets a 0 or a 1 depending on the version.
The direct link to the manual for the NFW7300WW00 is: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10252719.pdf . The direct link to the manual for the NED7300WW0 is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10240875.pdf .
I hope this helps.
Posted on Jun 28, 2011
SOURCE: I have an Amana Tandem 7300 and when it cycles, gray powder is everywhere and some of our clothes have been ripped up while being washed. Please tell me this is an easy fix which I can do myself!!
I have the same problem with my 7300. The grey material is actually the door gasket being rubbed and abraded away. Mine finally wore through the gasket entirely and had to be replaced. I have yet to find out why, or find anyone who knows why.
Posted on Apr 29, 2012
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
Will not advance to wash after selection beeps on wash. But does not go on
Pump blocked .down at front of machine water willcome out so be prepared with towels etc.clear blockage
Nov 21, 2015 | Amana Tandem 7300 Washer and Dryer Stack...
Heat sensor on electronic dryer amana tandem 7300
Yes, the dryer has a heat sensor.
Feb 24, 2015 | Amana Dryers
Dryer keeps blowing 30 amp fuses
usually one of 2 things,either the 240volt heating element is shorting out to the element housing or the dryer drum motor has bad windings or the end bearings are dried out causing the motor to work harder and draw excessive current to start and keep running
Oct 23, 2012 | Amana Tandem 7300 Washer and Dryer Stack...
Amana 7300 tandem Dryer
Did you find a solution? Mine is doing the same thing.
Jan 05, 2012 | Amana DLE330RAW Electric Dryer
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
Washing Machines Logo
656 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
