Question about Sewing Machines
Stitch selection dial stuck
The switch selection dial on this machine is solid and will not rotate in either direction therefore stitch style cannot be altered. The back is off the machine and I can see a small cog on the end of the selection shaft which mates with a larger plastic one but I can see no way of releasing it. Any knowledgable help would be appreciated
3 Suggested Answers
  • 5 Answers
SOURCE: can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Posted on Apr 13, 2009
SOURCE: I have an old kenmore
make sure stitch length is in proper color area
Posted on Dec 02, 2010
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
Do not know how to set the machine for simple straight stitch.
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Mar 01, 2011 | Singer 1725
I'm looking at the Pattern Selector Dial. 2 different stitches are shown for each selection A - H. 1 shown in blue 1 shown in green. Does each pattern have 2 options?along the rt side of the machine also...
i have same machine, you know i found that to be odd too. heres what you do, click it to the letter you like the style, then start sewing on a swatch at the very shortest stitch. then start increasing the stitch width more and more, up to 4 and see how it difers. i think thats where you will see the difference. i haven't played too much with mine yet, but listening to you is encouraging me to play on a swatch with all the difffernt styles you can stitch.
Jun 17, 2010 | New Home 2014LE Mechanical Sewing Machine
I need to know how to change the utility settings?
You have not said what model you have but I suspect that the other 11 stitches are stretch stitches which will mean you have a seperate dial to select, if you could email a picture of your machine I will soon know.
drivewithken@blueyonder.co.uk
Oct 30, 2009 | Necchi Sewing Machines
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
Janome My style 16 - stretch stitches
hi , i have one the same and yes you do have to force itjust that bit further on the [length] dial till u see a green triangle, it is just past the 'o' then select the green stitches you want, i hope this helps happy sewing from georgi
Jun 14, 2008 | Janome MyLock 634D Mechanical Sewing...
Can't select stitches 11-21
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
