Question about GE Profile DPSB613G Gas Dryer
DRYER WILL GET HOT THEN SHUTS OFF WITHIN A MINUTE
    Sergeant:
    Champion:
  • 234 Answers
I would check the belt on the fan.The hi ,imit is turning the unit off
Posted on Mar 13, 2009
Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
May 15, 2010 | Asko T701 Electric Dryer
Gas dryer does not get very hot.
the dryer dries after two or three tries
Dec 29, 2009 | Kenmore Dryers
Bosch WTMC3500UC gas dryer runs but does not heat
my dryer does not put out lint, rather thru the front.
Aug 22, 2009 | Bosch Dryers
Dryer shuts off after a minute or so
You have a bad motor . Only possibility .
Jul 18, 2009 | Whirlpool Dryers
DRYER STARTS BUT IMMEDIATELY SHUTS OFF
If you are having the same problem I had, the motor gets hot and shuts off. My motor was making a fairly loud noise when I cut it on. It would run for a minute or two and then shut off. I had to replace the motor. Motors are fairly cheap and not that hard to install. I paid $50 for a new one on ebay including shipping.
Jul 18, 2009 | Kenmore 63942 Dryer
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Dryer turns off after one minute.
Sounds as if your high temperature thermostat is going bad or is bad. Check your thermostats. If your dryer gets to hot this will shut it down for safety reason!
Jan 09, 2009 | Kenmore 66832 Dryer
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
My dryer smells hot and shuts off it is a Maytag model LDE8406ACE
This happens when the dryer gets too hot and a thermal breaker (or thermal fuse) kicks in. The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts itself off to prevent a fire.
Sep 22, 2008 | Maytag Dryers
Whirlpool dryer - element heats, then shuts off quickly
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Mar 18, 2017 | Whirlpool Dryers
Open Questions:
Black marks from dryer My GE Profile dryer which is only about 5 years young is now leaving black streaky marks on my white sheets. I've discovered this only happens on my sheets since they are the only thing I dry on high. I've never seen the marks on any other light colored loads that I do on medium heat. And I could never figure out where the marks were coming from. And regular Shout, laundry soaps, bleach, etc. did nothing to remove them. I had to do two back to back dryer loads on high both full of sheets after company and after the second load I noticed some black residue on one of the upper corners of the door which opens left to right, with this residue on the top inside right of the door. I wiped it off with a finger first and it's more powdery than oily. Reminded me of graphite from a pencil. I took the used dryer sheet and wiped the rest off the door and then looked at the dryer in the corresponding location. My dryer model # DPSR610EG0WT has white plastic edging between the inside of the door and the drum. This powdery substance is coming from both sides of this plastic edging on the top exactly where I saw it on the door. I crammed the dryer sheet in both sides inside and outside of this edging and wiped around it and it was BLACK from this stuff!! I tried some Carbona grease cleaner on my sheets and I thnk that worked for the most part to remove the marks on my sheets. But now I have to rewash and redry them all over again. What is this stuff and what do we have to do to stop it from happening? My husband is a master mechanic from birth (even though he has a white collar desk job) and can repair and fix anything. Now he's listening to me since I told him I'll start drying his shirts on high! Please advise!
Apr 23, 2013 | GE Profile DPSB613G Gas Dryer
GE Profile DPSB613G Gas Dryer Logo
75 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
