Question about GE WSKS2060WWH Top Load Washer
Washer won't spin and keeps filling
I have a GE wskp2060 in my RV I just purchased.  Ran the washer for the first time and it spun so hard it knocked the walls.  Now, when I turn it on, it won't spin.  It acts like it wants to engage, but instead, starts filling the tub continuously.  It drains, then fills, like it skips the spin cycle.  Help!  Don't want to pay a repair guy if I can fix it myself. Checked the drain hose, it is not clogged.  No other clogs that I can find.
    Sergeant:
    Champion:
  • 234 Answers
One thing is wrong is balance.That's why it knock the wall down.Don't know to much about GE.But I would check the dasher to see if it's down.But the belt could be broken under the washer.
Posted on Mar 13, 2009
Will fill but won't wash
Sounds like the timer,that is the brains of a washer,if the time fails it will not run certain functions,in you case it is the spin .
Sep 21, 2012 | GE Profile Prodigy WPSE4200A
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Engine problems
it can be a spun bearing or the rod itself gets wore out and stretches into an egg shape this will also cause a knock but usually when a bearing spins it will make the engine hard to crank over. then as it wears out the knock will develope, or it will just suddenly appear and the blow apart.
Dec 11, 2007 | Car Audio & Video
Final Rinse
im a repairman and just ran into that same problem on the ge washer. the problem is the control board. That control board is expensive, but it will fix the problem
Feb 02, 2007 | GE WJSE4150B Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
GE WSKS2060WWH Top Load Washer Logo
145 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
