Question about Fish
Bulb keeps burning out - Fish
Same low beam headlight keeps burning out ive replaced 3 now same side headlight in 7 years???
check that you have a good ground, if you do not it will cause it to do that
Mar 19, 2014 | 2007 Dodge Dakota Cab SLT
My samsung bulb keeps burning ouit every 6 months
YOUR TV MUST NOT BE SUROUNDED BY BIG IMPOSSING OBJECTS YOU MUST HAVE AT LEAST 3 FEET FROM BACK WALL THE COOLING FANS MUST BE CLEANED OPEN BACK COVER AND CLEAN FANS IF LAMP STILL BURNES AFTER YOU MAY HAVE A BALLAST PROBLEM
Jul 30, 2010 | Samsung HL50A650 50 in. TV
Keeps burning out when i replace them-headlights.
I had the same problem with 2 different vehicles. Kept burning out the replacement bulbs, and they never lasted very long. I was told that I should never touch the bulbs with my bare hands/fingers because it transferred oil onto the bulb which would in turn create a hot spot on the bulb and cause it to burn out. I tried changing the bulb while wearing hospital type thin latex gloves. I also made sure not to touch the bulb to anything else while guiding it into its proper position. I know it sounds silly, and it may just be a coincidence, but I have not had the problem since I started installing bulbs this way.
Apr 25, 2010 | 2002 Nissan Xterra
Car headlight bulb keeps burning out!
Must have a bad seal or broken/chipped lens allowing moisture to build up inside headlight.
Jan 16, 2010 | 2004 Hyundai Elantra
HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
Jun 09, 2009 | 2001 Mercedes-Benz C-Class
Headlight keep burning out
you might be using a higher wattage of hallogen bulb. higher wattage bulb must have a relay so it'l stop from burning. and you save money.
Apr 15, 2009 | 2005 Kia Sorento
Wd-57731 bulbs keep burning out 3 bulbs burnt
Contact Mitsubishi. Their is a national recall on that TV. GET then to replace the TV.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Televison & Video
Driver's side turn signal light keeps burning out
My 1998 Oldsmobile Intrigue drivers blinker keeps blowing out. I have spent too much money on this car and I need to know what if I can fix this problem myself and if so how?
Mar 04, 2009 | 1998 Oldsmobile Intrigue
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Mar 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Fish Logo
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
