Question about Kowa Optics
Lens cap missing lens cap
Nikon scoutmaster 2 eyecups and lens covers
Direct from Nikon, ebay or others
Binocular Parts from Nikon
https://parts.nikonusa.com/en/nikon-products/binoculars-parts/index.page
  1. Cached
  2. Similar
Service & Support. Nikon Service and Support · Product Repair · Product Manuals · Nikon Knowledgebase · Nikon Professional Services · Contact Service & Support ... Missing: scoutmaster
Binocular Lens Covers ' eBay
www.ebay.com/bhp/binocular-lens-covers
  1. Cached
  2. Similar
Find great deals on eBay for Binocular Lens Covers in Binoculars and Monoculars Equipment. Shop with confidence. ... Nikon Binocular Lens Eye Cap Covers. $15.00. Buy It Now. Free Shipping. Nice used Nikon ... New Lens Eyepiece Cap Cover For Binoculars Spotting Scopes Telescopes CCTV M12. $3.57. Buy It Now. Missing: scoutmaster
Nikon Service and Repair - Nikon Sport Optics
https://www.nikonsportoptics.com/en/service-and-support/service-and-repair.page
  1. Cached
  2. Similar
Nikon Dealer Service Account. Nikon dealers can schedule, manage and track all their repairs in one spot. Sign in with your dealer number · Cover art for the Summer 2012, Spring 2012 and Winter 2012 issues of Nikon World ...
Caps & Rainguards for Binoculars ' B&H Photo Video
https://www.bhphotovideo.com/c/buy/Caps-Rainguards/ci/2623/N/4083534117
  1. Cached
  2. Similar
Items 1 - 24 of 46 - Add to Wish List Item in Wish List. Vortex Tethered Objective Lens Caps for 50mm Diamondback Binoculars (Set of 2). (2) .... Comfortable Rubber Eyecups; Fits EL and SL Binoculars. In Stock. Order by 4pm to ship .... ZEISS One Push-On Eyepiece Cap for the 8x30 B/GA IF Classic Binocular (Replacement). Missing: scoutmaster
Nikon scoutmaster eyecups and lens covers Google Search
Feb 21, 2018 | Nikon Cameras
Lense stuck out, cap error message
try to take out the battries for like 5 minites and so on if there is no obstuction with the lens there will be a fault in the camera and will be difficult too relace your self its better off sending it back as it seems the sensor inside for the lens is buggered thanks from chris plz rate
Sep 24, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Remove stuck rear lens cap
The first thing I would try is using one of those rubber pads that are used for removing stubborn lids from jars. If that dose not work, I would use the fact that the Nikon rear lens caps are made out of soft plastic to my advantage. If you have a Dremel rotary tool with a disk cutting tool, you may be able to CAREFULLY and slowly cut away the lens cap. You didn't say which lens this is, but since with most lenses the telephoto position moves the rear element away from the back of the lens, I would set the lens to telephoto before starting to cut. I would start by cutting through the back of the lens cap. Cut a little at a time and try to take off the cap. Proceed slowly periodically trying to remove the cap. Hopefully, the pressure will be relieved and the cap will release before it becomes necessary to cut across the lens flange. When you are done, I would carefully clear the lens of any debris.
Jul 05, 2014 | Nikon Cameras
How to remove stucked lens cap
It depends what lens cap you have some lens caps you pinch off
Others you pull off some screw off its the easiest thing you can do on the camera you should have had a a1 filter screwed on before the lens cap then all you would have done is unscrew it all.
Then again you may have to take it to Nikon on Wilshire
Jun 08, 2014 | Nikon D3100 Digital Camera
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
Broken rear lens element on Nikkor Noct 58mm 1:1.2 lens
I recommend to call Barry Edmonds Nikon technician at Fixation UK LTD
44 20 7091 2550
All Best
Rafal
Jun 16, 2010 | Nikon Cameras
The zoom portion on my lens is stuck.
http://www.unitedcamera.com/lens-repair/#brand41
They offer chat and free estimates, that is the best thing to do for a lens like that.
Oct 22, 2017 | Sigma Zoom Normal-Telephoto 50-500mm...
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Sep 10, 2009 | Casio Exilim EX-Z57 Digital Camera
Bushnell 700x76
Just got a 78-8831 and set it up according to instructions. After inserting lens into eyepiece, I can't see anything at all. Dont worry, I've removed the front cap from the the main telescope.
Something leads to believe I'm either missing something real fundamental or my telescope is broken. Please help
Jan 29, 2008 | Bushnell 3" Reflector Telescope w/Talking...
Optics Logo
29 people viewed this question
Top Kowa Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Kowa Optic Expert? Answer questions, earn points and help others
