Input doesn't work It just says unusable signal
  • 104 Answers
You will need to replace the main board as long as you have video going to the set. Have you tried to replace the cable going to the set? Have you also verified the video source?
Posted on Aug 17, 2014
  • Lou Labetti
    Lou Labetti Aug 17, 2014
    you will need to replace the main board as long as you have video going to the set. Have you tried to replace the cable going to the set? Have you also verified the video source?
3 Suggested Answers
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
SOURCE: Unusable Signal
Check your fuse on the main board I think it is bad
Posted on Jan 21, 2013
Unusable signal
This is a resolution mismatch problem. One of the devices will not accept the resolution of the other. Try another type of connection or try another input.
Apr 13, 2014 | Sony DVP-SR200P DVD Player
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
My 61in rca scenium is saying unuseable signal and there is no sound or picture
For whichever input the monitor is currently set to (i.e. Input 1, HDMI 2, etc.) it is telling you that the signal it is receiving is unusable. The question first is the monitor set to the input you truly wish to use?
If it is, then check the cabling between the monitor and the source device (cable/satellite box, game box, etc.) If you believe it the source is working, try swapping the cable or using a different input.
If that fails, try hooking up the source to another monitor and seeing if it works there. If you have a long cable run, try higher quality cables, the video signal can degrade over long runs (> 25').
It sounds like the monitor is receive *a* signal, just not one with enough data to be useable. Probably a bad cable.
May 06, 2011 | RCA Televison & Video
Dec 05, 2009 | RCA L42WD22 42 in. LCD Television
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Unuseable signal
WHAT HAPPENS WHEN YOU USE A DVD INPUT (AV) OR A SAT/CABLE BOX CONNECTED TO THE AV INPUT'S ,,IF IT CLEARS UP YOU HAVE A SIGNAL BOARD BAD BUUUUUUT YOU CAN BYPASS THAT BOARD AND SAVE MONEY JUST BY USING THE AV INPUT...TUNICA
Sep 25, 2008 | RCA P52926 52" Rear Projection Television
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
