Question about Vehicle Parts & Accessories
Audi a6 2003
The signal light doesn't blink
    Sergeant:
  • 358 Answers
The audis are notorious for failed flasher relays which also affect blinkers. It is intergrated with the 4 way flasher switch. Bring vin# to dealer or bring switch.
Posted on Jan 24, 2016
  • 460 Answers
Try pushing in the hazard button in and out a few times and try signals again. If no change in fuse box or next to the turn signal relay is not working. Can check it by taping on it while turn signal is on
Posted on Apr 25, 2013
I have a 1991 celica and for some reason the front signals does not work at all. When I turn on the blinkers it blink really fast on both sides but hazard light works fine it blinks normal but it...
check the main earth wire near the battery. and one near the rear of the lights. unbolt them and clean the connectors up put some grease on them after. then check again. remember that when the earth wires come off the radio code will be needed to reset the the radio. be safe and take the battery off.
Sep 28, 2013 | Cars & Trucks
97 Oldsmobile bravada my right brake light won't
Sounds like a short in the socket or a bad ground.
The parking light is one circuit and the brake turn signal is another.
Jul 24, 2013 | Cars & Trucks
My right signal doesn't blink but the bulb lights are on
If the left signal light is affected as well then the flasher can is faulty.
The flasher can is located under the dash.
Jan 08, 2013 | 1995 Buick Park Avenue
Directionals go on but don't blink
One side doesn't flash or both? Make sur ALL bulbs light up, try emergency flashers. If they work, probablt have a bad flasher relay under driver's side of dash. if not, may have a bad turn signal switch. They are well known for problems.
Oct 02, 2012 | 1995 Chevrolet G20
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
Turn signal flasher oldsmobile achieva 94 not flashing how do i fix
light goes on but doesn't blink is typical of a bad flasher unit. Flasher units usualy have two wire connections. Flashers can be round or square. Try replacing flasher with another known working flasher unit.
Apr 30, 2012 | 1994 Oldsmobile Achieva Special Edition
Hello, I have a 85' buick regal and I'm having
This is a tough one with out being able to see the wiring. i will enclose a wiring diagram for the complete lighting system.
You will need to locate the correct wirng and make sure its going to the correct light. Most times a bad ground wire will make the light do funny things like your car is doing. With the diagram i enclose locate the ground wire to the rear lights and make sure ground is good, even if you must cut old ground out and run a new ground to a good metal ground.
Mar 18, 2012 | 1985 Buick Regal
My 2004 toyota celica's turn signal clicks extra fast when it's set to turn right. Also the front right signal light doesn't blink. Is the problem a broken bulb or a broken flasher relay?...
most likely a faulty relay is all... fix that and you'll be fine, they tend to speed up to let you know that they're on their way out.
Jul 12, 2011 | 2004 Toyota Celica
The Right Turn Signal comes on, but doesn't blink on my 95 Buick Park Ave. I have a State Inspection coming up and need to get it fixed by this weekend.
It sounds like one of the signal lights is out. The best way to find out is to turn the hazards on and check if they blink. If they do then you might need a turn signal relay.
Good Luck
May 11, 2011 | 1995 Buick Park Avenue
Vehicle Parts & Accessories Logo
89 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
