Question about Philips Televison & Video
I need the codes for my remote and directions on how to program
I have a PHILIPS RC4350/01B remote control and do not know how to program to my tv, dvd recorder and my dvr. I need codes and instructions.
mewms_14904
  • 1027 Answers
SOURCE: remote code list
JVC DVD 0558 0623
Motorola Cable 0476 1106 0276 0810
Posted on Mar 06, 2008
SOURCE: Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
Posted on Jun 13, 2008
jmeredith
  • 417 Answers
SOURCE: Codes
hi,
heres what I found
might I suggest taping a piece of tin foil to the back of the remote, or put some velcro on it and stick it up and away. dogs hate to chew on metal, unless theyres food directly on it! (we have three shepherds)just a suggestion, heres the link, youll need adobe reader, hope thats the right remote. if not I found that info at www.radioshack.com and navigated to that remote type and in there I found it.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502147_PM_EN.pdf
J
Posted on Aug 05, 2008
SOURCE: program Universal Remote URC-R6
hi.. I am trying to program our Universal R6 remote to our emerson ewd2202 dvd/vcr but nothing seems to work. I have tried the list of codes given for emerson in general... but not sure if there is a way to figure out what the exact code is for a emerson ewd2202 code.
Posted on Sep 06, 2008
  • 4 Answers
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Posted on Jan 16, 2009
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
Need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Oct 24, 2009 | Philips Televison & Video
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
Remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
Aug 17, 2008 | Philips Magnavox Learning Universal Remote
Code for Sony tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
318 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
