Question about Sony KDS-60A2000 60" HDTV
Getting all snow with a "no signal" message power is good to box
    Top Expert:
  • Sony Master
  • 74,136 Answers
Check its ariel connection for firmness. If it is OK, check and replace its tuner.
Posted on Apr 25, 2013
Motorola DVR DCX3501-M loses power and guide info resets
We call it "flashing 8's" and a lot of things can cause it.
1st one of the signals that the cable provider sends to the box, we call it a "hit", will reset the box and tell it redownload
2nd I find dirty power (poor wiring, UPS or surge protector failing) can send the box spikes of power that make it think it recieved a hit.
3rd could be a problem with your cable signal. signal too high, yes it is possible to have too good a signal. maybe a bad amp in the alley behind your place or on your building. (any neighbors having trouble?)
4th maybe its a bad box.... gotta go bad sometime.
good luck
Mar 15, 2013 | Motorola Televison & Video
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Getting error message "Din Unlock
That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
May 03, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
Keep getting message 'no signal in 5 mins' then time runs down dont know how to clear it. lost manual
Is this on a Cable box or is this a message from the TV?
If this message is from a cable box you either have a low signal or a bad box either way a technician from your service provider should be able to correct this for you.
If this message is from your TV please post the TV make and model and we can try to go from there.
Good luck....
Jan 07, 2010 | Televison & Video
Not getting cable signal.
TRY CHANGING YOUR INPUT SOURCE ON THE MENU FROM AIR OR ANTENNA TO CABLE.
Dec 11, 2009 | Hisense TA42P-HDRA Television
The short version: Will a 14-year-old TV work with digital-to-analog TV converter? Specifically, I have RCA Model G25342AT, built in Sept., 1994. In case yes, converter should work... Trying to connect...
The converter box should work. Getting the remote to work with the TV might be a challenge. You might have to stick with two remotes. It used to be in the old days you could plug your tv power into the remote that way you would turn the tv on with the tuner remote but I be they stop doing that.
There is website that will let you check the digital televison signals for your area. This site should help you:
http://www.tvfool.com/?option=com_wrapper&Itemid=29
Jun 29, 2008 | Televison & Video
No signal converter box.
Why is this in the computer section?
Anyway, don't exchange the box just yet! First, can you access the converter's menu? Because mine automatically comes up with the "no signal, call customer service" message, but I can access the menu fine -- so the hook-up is not the problem. If you can access the menu, let it autosearch for you, because mine can't be used until I do this. If you get the "weak antenna signal message", refer to the user manual to find out how to check your antenna signal strength; if it's in the weak range, you have to buy a better antenna, most likely from the official source: http://www.accessHD.tv
You can always exchange the box and repeat the process. Getting the "no signal" message is a good indicator that you've hooked everything up right, especially if it's accompanied by a customer service number. You can email me at kalalkb@gmail.com and I'll try to help you troubleshoot the problem if you like. I'm up all night.
Jun 25, 2008 | Computers & Internet
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDS-60A2000 60" HDTV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
