Question about Frigidaire Dishwashers
My dishwasher will not start
Yesterday when I woke up the lights were bilnking as if the power in the house went off. Today when I went to use it nothing happens. No sounds, no lights, nothing.
    Brigadier General:
  • 8,619 Answers
Hi!
Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Please see this picture of what the dishwasher switch looks like.
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Posted on Mar 13, 2009
I have installed two woods cd500 series timers,for one month everything was fine came yesterday and no power to both timers. So started checking had power to both timers but red light was not on, so when i...
Usually when there is intermitent power like that there is a bad connection under one of the wirenuts. Remove the timers, untwist all wirenuts and start over.
Feb 11, 2012 | Woods Hardware & Accessories
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
I have a single dish drawer and it was working completely fine yesterday but today it wont turn on, there are no lights, nothing, no amount of button pressing is working please help
Assuming the circuit breaker at the mains is ok, you have a faulty power board or the thermal fuse in the heater assembly is blown.
To replace you will have to take the drawer out of the housing making sure you don't pull the hoses and the wires too hard.
Parts are available at heater and power board.
Please rate this solution to help fixya serve you better in future.
Sep 07, 2010 | Fisher and Paykel 23 in. DD603H SS...
Had a power cut today,top draw does not power up
I am assuming you lost power to the house while the dishwasher was running. The power is back but ou are not able to start the top drawer. Is that correct?
Was the top drawer operating at the time the power went off? Are you able to pull the drawer out?
Do any lights turn on when you press the Start button?
Jul 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
No power to dishwasher
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable. Replace if defective.
  5. Check the timer or selector switch. replace if defective.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Maytag Dishwasher: MDB/C-2 Suddenly Stopped Worked
I have had this dishwasher since 2003 and haven't had a problem whatsoever. This is one of the best dishwashers I have purchased out of the 4 I have had.
Jul 21, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Wont start
Give it a firm push over the door latch once you've closed the door..it might be the door switch not activating. oops.... first and formost isolate from power for 5-10mins and try
Dec 28, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Open Questions:
Dishwashers Logo
100 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
