Question about Carrier 38CKC042 Air Conditioner
Need help Locating replacement parts online
I have a Carrier 38CKC042 the motor went down and I am having problems locating a replacement motor for it. Where can I look online for replacement motors for this unit
    Scholar:
  • 144 Answers
You shouldn't have to get the OEM or manufacturers motor. Get the info. off of the old motor like volts, RPM and HP(horsepower) or just bring the motor to an appliance parts store. They should be able to match it up. Make sure that you get a new capacitor for it too. The cap. rating will be something like 5mfd on the motor.
Posted on Mar 13, 2009
Use an Emerson 3403 on it......
Posted on Sep 09, 2009
Carrier air conditioner model 38yca030370, need to know what kind of capacitor it needs?
Have him bring the old one back as it is yours. Check for the megaferons it has and the capacitance rating. Problem is hooking up thie wires needs to be done with knowledge of the system. $60 for a capacitor, $1200 for a blown compressor if hooked up wrong. You decide
Apr 20, 2013 | Carrier 38CKC042 Air Conditioner
Carrier 38ckc036350, need a fan blade.
If you have the blade removed take it to a hvac parts house or appliance parts house. Carrier may not sell you one? but may give the pitch and size, rotation etc. If you cant get the blade off remove the entire motor, it needs a puller to remove.
Aug 31, 2011 | Carrier 38CKC042 Air Conditioner
Air conditioner model # 38ckc 42..350 not working, keeps tripping the breakers, had electrician check out and stated it was the fan or the compressor, i bought the house in 2009, was built in 2005, what do...
Hi, if that is a 2005 carrier condenser, it may still have a warranty on the compressor. You need to copy down model and serial #, call the local Carrier rep and ask. That is your right to do so. The fan is probably not in warranty, but it is definitely worth replacing if it is bad. I sold carrier for 15 years, and sold many with 10 year parts warranty. First thing you need to do if you haven't done so is check on your warranty! If you can explain what it is doing a little more in detail I could probably tell you exactly what is wrong. Hope this helps.
Jun 23, 2011 | Carrier 38CKC042 Air Conditioner
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
My fan motor on a carrier 38ycc024310 has been changed two times should i replace the heat pump or is there an electrical problem
Most Carrier units use smaller horsepower motors with less rpm.
If a universal motor was used that may be your problem.
Check the specs listed on the unit and replace with the correct motor.
Also replace the capacitor.
Dec 18, 2010 | Carrier 38CKC042 Air Conditioner
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
HI can you help me?i need to find out year of
I had just contacted my Carrier parts store and that model and serial does not come up. Will you please double check. Russ
Mar 25, 2010 | Carrier 38CKC042 Air Conditioner
Carrier air con. expansion valve 5 problems and 5 solutions
1. Mid to late 90's problems on Carrier coils leaking. 2. Problem with lication of TXV's on air handlers. When welded in they were located to close to the fitting where the suction lines were welded in to unit. The heat would cause them to fail.
Feb 21, 2010 | Carrier 38CKC042 Air Conditioner
We require condenser fan motors for Interclisa Carrier package (rooftop) air conditioner model AAD 250 (1980's model) model. Air conditioner - supply voltage 380 Volts 50 Hz AC. Condenser fan motor voltage...
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
Jan 21, 2010 | Carrier Heating & Cooling
Driver side window won't go up
the window regulator needs to be replaced. any parts store should have these as they break all the time
Oct 15, 2008 | 1996 Dodge Dakota
Carrier 38CKC042 Air Conditioner Logo
154 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
