Question about Briggs & Stratton Garden
Repair Diagrams oil leaking around sump pan
  • 64 Answers
You need a crankcase gasket and seal. TIP: Try snugging up the crankcase bolts first!
Posted on Apr 13, 2014
How to replace oil pan seal
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html
Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 16, 2012 | 1996 Cadillac DeVille
Fuel is getting into oil pan
Car oil leak?
This will help.
Thanks.
Feb 15, 2012 | 1996 Lexus ES 300
How do i remove oil pan
Car oil leak?
This will help.
Thanks.
Feb 10, 2012 | 1995 Buick Century
2002 Lincoln LS V6 oil leak
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
Car oil leak?
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
This will help.
Thanks.
Feb 07, 2012 | 2002 Lincoln LS
Oil pan 2007 trailblazer
Car oil leak?
This will help.
Thanks.
Feb 04, 2012 | 2007 Chevrolet Trailblazer 4.2
Oil drain pan on dodge durango
Car oil leak?
This will help.
Thanks.
Feb 03, 2012 | 2008 Dodge Durango
How to replace the oil pan on a 98 pontiac grand prix 3.8 liter
Car oil leak?
This will help.
Thanks.
Feb 02, 2012 | 1998 Pontiac Grand Prix
I relaced the radiator, rad cap thermostat and flushed and put new coolant. everything is hooked up correctly. i have 3 water leaks around the bottom of the sump pan. for the life of me ive never seen this...
There is no water jackets anywhere near the sump.You have a leak that is running down the side of the engine and appears at the sump.Let the motor sit and cool down.Top up the water and with a torch in hand,start the motor.The fans will push water towards the rear of the motor.Start looking.Best in the dark because you will see the shine of the water.Check thermostat gasket and around the water pump.Hope this helps
Nov 02, 2009 | 1993 Toyota Corolla
Oil leak in punto
The punto's suffer from porous sumps. The metal becomes thin and leaks oil. Although its not a difficult job to change, its a messy job. You have to draain all the oil out first, then remove all the bolts around the sump pan. If you are replacing the sump, its good practice to replace the gasket too.
The sump itself is not too expensive to purchase, and the job itself in a garage, shouldnt take any more than 2 hours.
TL
Dec 17, 2008 | 2006 Fiat 124
Oil leak
hi common fault on these is the oil switch oil runs down the block around the oil filter and down the sump as you are driving along the air draft blows it all over the place so clean it up run the engine and from underneath the car see where it is coming from the only other things on the sump that would leak are the sump plug washer and the crankshaft main oil seal at the rear of the engine it will be the switch best of luck paul
Oct 15, 2008 | 1997 Honda Accord
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
