Element eldft406 No picture or sound. TV won't power on
SOURCE: TV won't turn on.
I say press the input button until you see a picture!.
Posted on Jul 06, 2011
electrotech1
  • 1126 Answers
SOURCE: Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Posted on Sep 14, 2011
budmrtn
  • 11361 Answers
SOURCE: I have an Element FLX
Check the two caps (10uF 450Vdc) by the inverter transformers, also check fuse F2.
Worst case will be shorted out ballast caps in the LCD panel assembly.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Posted on Oct 31, 2011
MNfisherman
  • 11896 Answers
SOURCE: TV won't turn on. I hear a clicking noise near the power supply. I have no picture or sound
This is usually and most likely caused by the power inverter/board. There are capacitors and other components that can burn out and will cause the power not to be transfered correctly
Posted on Jun 06, 2012
kd1s785
SOURCE: element tv Model ELCHW402 won't turn on
I know my way around electrons and I plan to tear my set down and replace ALL the capacitors with known, good capacitors. I bet that'll do the trick as this set ran nearly 24/7 for almost two years.
Posted on Jul 23, 2012
Turns off
Main board fault. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 10, 2014 | Element Electronics ELDFT406 40" LCD TV...
Eldft406 tv is popping and no sound is coming out.
What is popping? Do you hear popping from the speakers or the back of the TV? You could have a serious issue on the power supply of the TV making this sound. Below is a link to the power supply for that TV.
http://www.tristatemodule.com/p-26991-lk-pi400112z-westinghouse-tv-module-power-supply-cqc04001011196-eldft406-cw40t2rw.aspx
Nov 04, 2013 | Element Electronics Televison & Video
Element ELDFT406 shuts off by itself every 10-60 minutes
Ok, I am having the same issue. I just bought my tv - same model at the Target Black Friday sale. Can I ask, did yours make a low humming noise before you changed it out. I still am within my 30 day exchange policy, so I am thinking it would be wiser just to exchange it... but my concern is, would I get one with the same problem (or worse) in exchange?
Dec 09, 2012 | Element Electronics Televison & Video
I tried to register my new Element Electonics 40" Model - ELDFT406. Says model # doesn't exist ? Also having trouble getting the tint setting.
so you shouldn\'t bother too much with it. I have the same model and it shuts itself off whenever it chooses to. I\'ve only had it since the 23rd of November, and it shut itself off after 2 days and maybe being on only 6 hours in those two days. It shut off the other day after 40 minutes. Read the reviews on Target\'s site, most people have issues.
On Facebook, the manufacturer said they would be adding this model to their site within a week, and that was around the 26th of November that they said that and it\'s still not on their site yet. I got mine at Target and I have 90 days to return it, so I\'m going to wait until TVs go on sale around the beginning of Feb and return it.
Dec 03, 2012 | Element Electronics HD LCD TV ELDFT404-B
Eldft406 HD Digital LCD TV.Just got it and the sound goes in and out.
I have this same one and it shuts itself off at random, one time after only being on for 40 minutes. It started within 2 days of it being set up and it was maybe used for 6 hours total when it first shut off. The remote hardly works too. Other people have the same problems with this TV, read the reviews of it on Target\'s site. I got mine at Target so I have 90 days to return it and I\'m waiting until around the beginning of Feb. when HDTVs go on sale again. I suggest you just return it,. You can\'t even find it on the manufacturer\'s website.
Nov 29, 2012 | Element Electronics HD LCD TV ELDFT404-B
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have an Element FLX 3210 that won't light up and show a picture..it has the sound but no picture.
Jun 04, 2011 | Element Electronics FLX3210 32 in. LCD TV
When i turn the tv on it comes up the main screen like,tv, hdmi,1 exc.then with in secounds it goes to a black screen it will not let medo anything unless i turn off and does the same thing i need help...
You have a power supply problem. Within about 32 seconds the picture drops out because the backlite transformers shutdown. Yoy will have to find a new power supply or have some one fix yours.
Mar 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
Electro Med Services...
