Question about Craftsman Garden
Craftsman 4 cycle weedwacker will not shut off
Doe anyone know how to fix this problem? It has an off button, which used to work, but now it doesn't. The only way I can turn it off now, is by pulling the spark plug wire. I'd like to fix this, cause I've been shocked a few times turning it off.
  • Craftsman Master
  • 7,482 Answers
Hi Vincent
In order for the switch to work it has to ground out the coil when turned off...
Sounds like one of the wires came off of your switch or the switch is faulty.
Check to see if any of the wires came loose, if not then replace the switch.
You can get parts at www.jackssmallengines.com
Bud
Posted on Apr 25, 2013
  • 4 Answers
SOURCE: Runs fine when first start. Dosen't want to start after warmed up.
Have you checked or Changed the Fuel Filter.
It will be in the tank hooked to the fuel line. I suggest a small pair of Hemostats for this job.
Posted on May 25, 2009
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Posted on Jul 31, 2009
  • 100 Answers
SOURCE: 32cc Craftsman weedwacker dies at idle
could be blocked muffler
Posted on Aug 14, 2010
  • 5603 Answers
SOURCE: I have a troy built 4 cycle trimmer. I pull on
If you can sense that the shaft is turning, then the valves are sticking open.
Posted on Jul 23, 2011
JAL69692002
  • 334 Answers
SOURCE: my 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Posted on Nov 15, 2011
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Weedwacker overheats
air leak around crankshaft, scrap it and buy a new Stihl.
May 23, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I have a craftsman weedwacker, I don't know how to
Most weedwackers are 2 cycle (stroke) engines, meaning the gas and oil are mixed together before you pour it into the gas tank. If it's a 4 cycle engine it appears there is no dip stick or convenience way to check the oil, you can only replace it. Here's a youtube video that may help.
http://www.youtube.com/watch?v=eiu6zd460oc
Jun 18, 2012 | Cars & Trucks
My 32cc 4 cycle craftsman weedwacker won't run off choke
Nov 15, 2011 | Garden
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
What oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
May 31, 2010 | Craftsman 29cc 4Cycle Straight Shaft...
Garden Logo
42 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
